Anybody know what exact color the RTi Silver is?
teamjhertz
teamjhertz Posts: 363
edited January 2013 in Speakers
I am building a DIY subwoofer and would like to mirror the look of my current RTi set up. Does anyone know what paint code or brand paint would match the silver in the RTi8 front panel of the enclosure? I am sure a regular silver rattle can will get close but I was wondering if anyone had any luck matching it..
I am also looking at older Polk subwoofers from the same era as the RTi8 or CSi5 speakers. My goal is to purchase a grill from one of the models that is the same color/material that was used on the RTi lineup. Is the PSW505 the closest?
Thanks in advance.
  • teamjhertz
    edited January 2013
    Thanks that might be the best solution
    F1nut Posts: 52,342
    edited January 2013
    Try calling Polk.
  • teamjhertz
    edited January 2013
    will do
