2x MM2124 + C500.1
swerve
swerve Posts: 1,862
edited December 2003 in Car Subwoofer Talk
Hi, I plan to put 2x MM2124's in my trunk along w/ a C500.1 amp. Just to let you know im going for clarity (sp?). Problem is my trunk is sealed off from the cab of my car. I have a metal plate behind the backseat. Should I go with the MM2124's or go with something else? I already have the C500.1 so that's a must.
Thanks alot
cats.vans.bag...
Post edited by swerve on
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited November 2003
    2124's will be fine -- they should be just about perfect on that amp... i dont know if polk is under / over rating their stuff... but if you can pinch about 600 outa that amp at 2 ohms, then that'll do those subs just fine... even if you're down at 550, its still fine.
    dont sweat the metal plate man -- try it out -- if it aint loud enough -- cut the friggin plate.
    The Artist formerly known as PoweredByDodge
  • swerve
    swerve Posts: 1,862
    the metal plate sucks, but ii have a feeling it will be all good.
    thanks alot
    cats.vans.bag...
  • swerve
    swerve Posts: 1,862
    thanks alot
    cats.vans.bag...
  • swerve
    swerve Posts: 1,862
    just put in my c500.1 tonight.... it's so clear, im loving it. I only have one 12 currently but that changes next month when i pick up 2x mm2124's.
    cats.vans.bag...
