dvd keeps skipping....
michael_w
michael_w Posts: 2,813
edited December 2003 in Electronics
Just looking to find out what I can do to stop my piece of crap dvd player to stop skipping. Everytime I slide out of my recliner or stand up from it makes a bit of static and my dvd skips. It only started doing this about a month ago. I'm eventually going to get a panasonic dvd-s55s or something similar but since I dont have the cash I'm going to have to put up with my crap one for a while longer. Any suggestions?
Post edited by michael_w on
  • sachinsood
    sachinsood Posts: 46
    edited November 2003
    Mike,
    What DVD player do u currently own? To prevent dvds from skipping, the better ones come with larger disc stabilizers that absorb shocks and also dual shock absorbing covers.
    Cheaper brands of course do not have such features. Their primary function is to play a dvd for as long as they can and thats it. They do not have any good disc stability hardware/software built in.
    You can get some good deals on DVDs at www.clubmac.com or www.jandr.com. Some time ago, clubmac had Denon DVD900 refurbs for $109 in comparison to the retail price of $249.99. I have a refurb HP laptop that has lasted me for 18 months w/o any kind of problems...so I do have some faith in good brand refurbs (if ur short on cash right now). Also, go to www.dealtime.com or www.shopping.com to get the best prices on a certain product from various retailers.
    Also, for the time being all I can suggest is...once u play ur movie, don't get up from the recliner. If you do, pause it. Disc skipping may cause scratches on the disc.
  • michael_w
    ok thanks i'll have to check out some of those.:p
  • ken brydson
    ken brydson Posts: 9,005
    I don't think skipping could possibly scratch the disc as nothing touches it. As a quick fix try isolating the player a bit. If you've got an old mouse pad laying around, cut 4 pieces and place them under the players feet and see if that does the trick. There are alot of "higher tech" isolation/damping materials but this cheap fix might do it for you. Good luck!
  • michael_w
    hmm it seems it only skips when I use the coax connection cause I just tried using the analog (2 ch) and it won't skip. so maybe the coax is extra succeptable to static....
  • burdette
    burdette Posts: 1,194
    I think I'd at least try working with the cable, and maybe a new cable. If it does it ONLY with the coax, then it doesn't sound like it is the transport. Maybe the cable is loose... or bad.
  • phoneisbusy
    phoneisbusy Posts: 867
    Hi Michael,
    At the risk of sounding obvious, what type of cable are you using for your digital coax cable? I would agree with burdette's assessment that the coax cable may be suspect.
    Welcome to Club Polk, good to see some others from my neck of the woods.
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • michael_w
    I'm using a plain rca cable for my coax (cause a guy from the store I bought my amp said that an rca works fine instead of buying a real coax cable). So maybe thats my problem - I need a real coax cable. But before I go and buy a coax cable im going to try a different cable and see if it changes anything.
  • michael_w
    O yeah dave forgot to ask where do you live?
    Welcome to Club Polk, good so see some others from my neck of the woods.
  • phoneisbusy
    Many people say you can get away with plain rca cable and I've seen some friends who have used it with no apparent loss of quality. Your setup appears to be more sensitive.
    If you can find a shop that will let you try the digital coax and return it (if doesn't improve things significantly), that would be great. At the very least, you might want to try a video cable, it has the same 75 ohm impedence and should be better shielded then the typical rca connectors.
    I'm out in North Delta now but grew up in 'Ditchmond' ;)
    We were out in the South Arm park area.
    regards
    Dave
  • michael_w
    So I tried a different rca cable to use as a coax and it did nothing lol. So I guess when I get some money i'll get a real coax but for the meantime when I plan on wandering around my room i'll just use the analog (cause it doesnt skip). Thanks for all your replys people!
