Polk CS245 vs. Axiom
Saint
Saint Posts: 4
edited November 2003 in Speakers
First question:
How much does/did the CS245 retail for? Or how much is it worth?
I can either keep my current center, a Polk CS245 I got really cheap or switch it for my friend's Axiom VP-50.
My mains are currently Axiom M22ti and I'd like to keep it all axiom of course, but not if the VP-50 gets owned by the CS245.
Polk CS245:
Frequency Response, -3dB 55Hz- 23kHz
System Impedance- 8ohms
Efficiency (1M, 1W) 90 dB
Woofer 2- 5¼" shielded
Tweeter1-1" soft dome shielded
Enclosure 6.4" H × 16¾" W × 9¼" D
Shipping weight- 22lbs
VP50 Specifications
Max Amp Power 125 Watts
Min Amp Power 10 Watts
Freq Resp +/-3dB (Hz) 100-22K
Freq Resp +3dB/-9dB (Hz) 80-22K
SPL in Room 1w/1m 91 dB
Anechoic SPL 1w/1m 87 dB
Impedance 8 Ohms
Woofer Dual 4.5"
Tweeter 1" hybrid
Dimens. (in.)(HxWxD) 6.5x14.75x5.5
Weight 7.5 lbs per
Post edited by Saint on
  • ken brydson
    ken brydson Posts: 9,072
    The key to the front stage is matching. Even if the Polk "owns" the Axiom, if it doesn't match/blend with your mains it won't sound right and you won't be happy. Best bet is to A/B if you can and let your ears decide.
    MSRP on the 245 was $250
  • Saint
    Saint Posts: 4
    Originally posted by ken brydson
    MSRP on the 245 was $250 [/B]
    Canadian?
    So what's a reasonable resale amount?
  • ken brydson
    Originally posted by Saint
    Canadian?
    http://www.polkaudio.com/home/products.php?category=5&speaker=42&recent=1
    $299 CN (see link) I don't know what a reasonable resale $$ would be. Probably $75-100 or so. Alot of great deals now on new units being closed out to make room for the latest models which won't help you much.
  • Airplay355
    Airplay355 Posts: 4,298
    why are those woofers black? mine are blue
    VR3 Posts: 29,659
    That is the CS245, not CS245i. They used black woofers instead of blue. Looks like a Polymer tweeter instead of a tri lam to. That polymer, IMO is my favorite Polk tweeter.
    The Polk will rule the Axiom, just by specs it looks like it will. I would take a 20 pounds speaker over an 8 pounder anyday. Just seems better quality materials and parts were used in the Polk which would mean better quality sound.
    I totally disagree that it has to match to sound good. I am running a Klipsch center and I wouldnt change my HT system any...
  • dan t
    dan t Posts: 206
    I'll take it a step further by saying maybe you don't need a center speaker at all. Most of the time (not always) channeling the center dialog through the fronts might be a better option. I found this true in my setup.
    Dan
