Finally got this vinyl cleaning thing down...
hochpt21
hochpt21 Posts: 5,423
edited January 2013 in 2 Channel Audio
I love spinning vinyl, and I am to the point with my system that I only want to spin cleaned records in nice condition on my main TT with my new cart. Between moving and busy life I havn't had the time and I only have like 20 of my 250 lps in "playable condition."
Well, we are finally getting settled and I have a system and station in place to make things easy. Each album takes about 5 minutes.
Here is the process...
Take vinyl out and place it on three microfiber cloths.
Drop five drops of Audio Technica record care solution on one half of the album...skip the label and drop five on the other half.
Take the Audio Technica brush pad and wipe completely around the album twice.
Apply light to moderate pressure and slowly "scrub" back and forth once completely around.
Take microfiber cloth and wipe side dry.
Repeat on other side.
Then I take the solution that came with my nitty gritty and apply the same amount of solution.
Gently wipe the solution twice around to wet the whole album.
Place the album on the nitty gritty and wet the other side as I slowly rotate the album while side one is being vacuumed.
Flip album over and dry side two with the nitty gritty.
Place clean album in a new inner sleeve and slide back into the cover next to the original sleeve.(new sleeve slides into the cover facing up)
Put new clear plastic outer sleeve on the cover.(new sleeve goes on facing up so the opening of the jacket, cover and sleeve are all different and protected)
Before I play each side...
I use an audioquest anti static brush on each side.
I use my new onzow zerodust sylus cleaner before each side as well.
It seems overly labor intensive, but I've got the system down so its really not. It's also a great feeling knowing that everything is as perfect as I can possibly get it before the needle drops.
Post edited by hochpt21 on
  • nspindel
    nspindel Posts: 5,343
    edited January 2013
    Get a Shark steam cleaner. I got that idea from DK's thread. That thing is awesome. You need to be careful not to get the label wet, but if you steam clean with distilled water and then vacuum you will be impressed with the results.
    gudnoyez Posts: 8,135
    edited January 2013
    The cleaning ritual is what it is all about:smile:
  • nspindel
    edited January 2013
    Yeah, I have a ritual, too. Put the record on the VPI, dust it, steam it, vacuum it 1 turn, MOFI deep cleaner, vacuum 1 turn, MOFI wash, vacuum 3 turns, flip and repeat. Then into a MOFI sleeve. It's a process, but man what a difference a clean record makes.
  • Irrenhaus
    Irrenhaus Posts: 1,094
    edited January 2013
    Wow I am getting back into Vinyl again is been more than 20yrs. But a very clean lp sounds really good. I have to get my ritual back in shape. Have to wait till I finish rebuilding my starter TT is a Philips 406 and I know is just the start on another rabbit hole......:')
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • hochpt21
    edited January 2013
    Irrenhaus wrote: »
    Cheers
    Well jump on in...there's more than one of us here, but plenty of room..
  • nspindel
    edited January 2013
    It's a very fun rabbit hole, though!
  • gdb
    gdb Posts: 6,012
    edited January 2013
    How long to clean these ???
  • hochpt21
    edited January 2013
    gdb wrote: »
    Just run that sucker through the car wash.
  • Msabot1
    Msabot1 Posts: 2,098
    edited January 2013
    Don't let yer LP's get filthy in the first place! Take care of yer stuff dude!
  • hochpt21
    edited January 2013
    Msabot1 wrote: »
    Well, since I was born after lp's stopped being produced for the most part...tell that to all the original owners :eek:.
  • Msabot1
    edited January 2013
    Hey man didn't mean anything other than well kept stuff will bring ya lots of years of enjoyment,something you can pass down to your kids someday! Treat those LPs with TLC you won't regret it! Welcome to vinyl dude!
  • nspindel
    edited January 2013
    For one thing, it's amazing how much even brand new vinyl needs a cleaning. Second, as a frequent buyer of vintage vinyl, there's nothing that makes me happier than taking a filthy record that I bought for $1, running it through the cleaner, and ending up with a shiny new-looking record. There is nothing more important than cleaning your vinyl. I spent more on my record cleaner than I did on my turntable.
  • vcwatkins
    vcwatkins Posts: 1,993
    edited January 2013
    Love my cheap plastic bathtub (Spin-Clean)! Throw a little Thierry Mugler in the water and they come out smelling good too. Kidding! Now if George will just stop selling his good old stuff, I might be able to catch up. OK I admit it, I'll never catch up.
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • doctor r
    doctor r Posts: 837
    edited January 2013
    Even with my VIP RCM I have the "received from George" pile that never seems to disappear. I have just accepted that there will never be a day that I am caught up on my cleaning duties :cry:.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • nspindel
    edited January 2013
    Slow and steady wins the race!
    SCompRacer Posts: 8,520
    edited January 2013
    hochpt21 wrote: »
    I was born way pre-CD. Back in the day we organized parties over new vinyl LP album releases. Always had my trusty Discwasher and dust bug! I have albums over 50 years old that are in better shape than I am. :cheesygrin:
    Still using Tergitol solution followed by clear distilled rinse on the Nitty Gritty, scrub with MOFI brushes, steam only when necessary. Heck, my Nitty Gritty RCM even has a CD cleaning attachment.
    edited January 2013
    doctor r wrote: »
    The way it should be! The to be cleaned and heard pile should always be large!:cheesygrin:
  • nspindel
    edited January 2013
    I bought an early pressing 1967 UK Mono Sgt. Pepper album on eBay. When I received it, it was filthy and it sounded awful. I first used my dust brush on it, that helped somewhat, but it was still really bad. You could actually see how much crud was in the grooves, I'm not just talking about fingerprints. Then I put it through my VPI, gave it the full treatment, starting with the steamer. Let me tell you, that 45-year old record sounds beautiful now, and is nice and shiny. And if you put it head to head with the cd, the ones that just came out in 2009, the old vinyl blows the cd away. And I'm only using a $70 cartridge. There is simply nothing more important when playing vinyl than having a very clean record.
  • doctor r
    doctor r Posts: 837
    edited January 2013
    Loved my dust bug! Still have the Discwasher with the slanted bristles as apposed to the useless ones sold today. Use it occasionally as the first step to lift a lot of visible debris. I have started using the Audio Intelligent three step process with Enzyme, Super Cleaner, and Pure Water. Excellent results. I Use the VPI brush on the enzyme and MoFi brushes for the cleaner and water rinse.
    I really miss the new album parties. What a great memory and a great time. (Or was that one of those if you remember it you were not really there situations?)
    rack Adona Eris 6dw
  • rromeo923
    rromeo923 Posts: 1,513
    edited January 2013
    I second the Steam cleaning. That in conjunction with vacuum can do wonders.
    I got static in my head
  • trans am
    trans am Posts: 91
    edited January 2013
    does anyone use woodglue? I need to clean my steely dan collection.
    Adcom GFP-750
    Adcom GFA-555II
    Monitor Audio silver RX2
    NAD T585 SACD
    Technics sl-1200mk2 / ortofon m2 blue (signal cable/ Eichmann mod / Sumiko HS-12 Headshell
    Jolida JD9 II / Mulllard Tubes
    SignalCable Ultra speaker cables
    SignalCable Analog 2 IC's
    "ROMANCE WITHOUT FINANCE IS A DAMN NUANCE CAN YOU DIG I???"
    edited January 2013
    trans am wrote: »
    So far everything I have encountered on a record was water-soluble and removed with my Tergitol solution or steaming. I've seen the glue method on the internet but never tried it.
  • nspindel
    edited January 2013
    The glue thing seems like a nifty gimmick, but not exactly practical. Apply the glue, them wait a few hours for it to dry thoroughly, peel it off, flip, and repeat. If you have a stack to clean, it'll take years!
  • trans am
    trans am Posts: 91
    edited January 2013
    ^^ I hear you buddy. I just wanted to know if anyone on the forum was into it. I do the dish solution method. its just getting motivated. My steely dan records are almost unenjoyable because they are do dirty. I need to get in the groove.
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
  • Dawgfish
    Dawgfish Posts: 2,554
    edited January 2013
    trans am wrote: »
    TA, I tried the dish solution and other home made methods I read off of the net for years. I used to use the steam cleaner method, along with a Spin Clean and used a shop-vac with a micro-fiber rag over it. It worked well but was very labor intensive. I did all of this because I did not want to spend big bucks on a rcm. Then one day I found a VPI 16.5 RCM on the Gon at a price I actually thought was reasonable and bought it. I wish now I would have bought a rcm a lot sooner. It makes cleanup a snap, even with very dirty records (when they are really dirty I still steam clean first) and I actually enjoy cleaning records now. I am listening to records in my collection that I haven't listened to in years because they were so dirty before. I guess what I'm trying to say is if you are serious about vinyl buy a rcm and never look back. They are worth it!
  • nspindel
    edited January 2013
    I ended up buying the 16.5 from Elusive Disc during one of their 10% off sales. I bought a kit that included a Mofi brush and the two Mofi solutions. If you consider the value of the brush and the solutions, plus the sale, I ended up spending under $500 for the RCM. Sounds like a lot at first, yes. But then consider the size of your record collection. I'm now at about 300 discs, and I'm certain it will grow to 500. If my collection grows to 500, then the cost of the RCM equals $1 per disc. Then think of how much the discs cost. In the case of new issue vinyl, the 180g releases can be anywhere from $20-$40 per disc. So the cost of the machine, when spread over the cost of the music itself, is actually miniscule. And the value it adds is huge. On the other end of the spectrum, consider the bargain basement Goodwill finds. I've bought a good amount of vintage vinyl, not just from Goodwill, but from George, eBay, Amazon, Craigslist, etc. It's quite easy to find great titles, sometimes even for as low as $1. But almost always, vintage vinyl is dirty. Personally, I would much rather have the cost of my vintage album be $2 instead of $1, but have it be shiny and clean. The sound quality is night and day.
    So yes, the RCM does seem to be a heavy chunk of money up front. But ammortize the cost of it across your record collection, and it really isn't that much. And the difference in sound quality it makes is huge. I hesitated for a while before buying one, but now that I have it I will never part with it.
  • hochpt21
    edited January 2013
    nspindel wrote: »
    Great post.
    It's even better when your wife buys you one for your birthday :cheesygrin:
  • nspindel
    edited January 2013
    And I'm sure your wife thought of that idea all by herself, and it was a complete surprise!
  • hochpt21
    edited January 2013
    Why do you think I have been leaving benchmark and jolida webpages up randomly at home. Birthday time is only a month away!
    edited January 2013
    hochpt21 wrote: »
    So you gotta go a whole month putting the toilet seat down and taking out the garbage without her asking?:cheesygrin:
    I asked my wife for a larger computer monitor once. She pushed my chair closer and said "There you go.":lol:
