update on hanging t.v
leftwinger57
Well I decided that my t.v. was big enough for the space I had and ordered the bracket a few days ago. The bracket
came I took the stand off the t.v. cleared the space,found the studs and the wall bracket was up in no time.I already
ditched that pile of gear that most of you guys did not like and is now spread out on the cabinet and it all works and tested fine. Thanks ,most of you guys said do it will give you more room and yes in fact it does and the living room
is configured a little different.One of these days I will fix whatever is preventing the loading of pix and show you the
new and improved living room.
Cool! I keep thinking I want to do this so my center channel speaker can be more at the right height. Should post some pics, I missed the other thread before you did it apparently.
Why didn't you post this to your original thread for folks that might have been following it? Just curious.If you can't hear a difference, don't waste your money.
1. didn't think of it and 2. I don't know how to do that .Besides it's not the most technically involved thing on here.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
