Question for spikes for SDA's
naturallight
naturallight Posts: 689
edited January 2013 in 2 Channel Audio
I have an old set of SDA 1c's studio models that had "maybe"..a 1 " mdf foot base around the bottom, which had, i think some plastic feet on them. Now they have been long broken off and now sit flat on the floor. Which is now a very "no pile" rug probably glued onto the cement floor.
So now there very easy to move around..to a 1/4 inch...LOL But they really should be spiked...the problem is.....what spike?
Now i have to drill holes in the bottom of the SDA's...not fond of that. But the spikes seem to run all over the place, as far as size and width of the spike. They seem to run from 5/8" to over 2" as far as height? I'm not sure about the width of these per say.
What if anything is the right size spike for these speakers...if there is such a thing???
Post edited by naturallight on
    EndersShadow Posts: 17,596
    edited January 2013
    Given you have to drill into your SDA's whatever spike you want to use is fine. With that said the normal spike you see is solid brass, or one of the ones from parts express.
    A long time back a bunch of us bought spikes from Meniscus Audio, specifically their Extra Point's sets and used those. However those are now sold out and I dont know what folks are using now.
    Link here: http://meniscusaudio.com/extra-points-p-1292.html
    I have seen folks use the parts express ones as well so they should do the job, but I have no experience with them
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    Are you saying you have removed the bases ? If not you would take a 2" block in each corner of the base and attatch the spoike to block.
    F1nut has described this process to many, I may be off base on how it is done but maybe he will see this thread and weigh in.
    If you have removed the base I am not sure what you do.
    pitdogg2 Posts: 25,745
    edited January 2013
    When i did mine i used these
    http://www.madisoundspeakerstore.com/tiptoes/feet/feet-yung-ybsc-black-chrome-tiptoe-1.5/
    I first turned the speaker upside down and drew around the spike in pencil then drilled in the center with 1/4 bit.
    The big piece is threaded all the way through 1/4x20tpi. I threw away the little threaded rod and insert and used 1/4x20tpi hex bolts and a fender washer to go completely through the base. Then i put hot melt glue over everything inside the cabinet.
    everything on this page in 1/4x20tpi will fit the spike if you decide you need a taller spike which help in the adjustment to level.
    http://www.madisoundspeakerstore.com/index.php?p=catalog&mode=search&search_in=name&search_str=feet
    The bottom of the spike is used to level. I did not plan on taking these off so i also used red thread locker but i have never had them come loose before, but make sure you don't get any on the lower part or you'll have some trouble when it dries.
    hope this helps.
  • teekay0007
    teekay0007 Posts: 2,289
    edited January 2013
    When I spiked my SDA-2B Studios, I didn't like, nor trust, the mdf "foot base" (pedestal) that was on the bottom of the speaker cabinet. I also didn't want to put spikes directly into the mdf cabinet because: a) I didn't think it was sturdy enough to hold the spike anchors very well in the long term, especially if the speakers were to be moved more than a few times over the next 30-40 years, b) I didn't like the looks of them mounted directly into the cabinet base and c) By replacing the mdf pedestal with something taller, along with the added height from the spikes themselves, I could get the tweeters up a little closer to my seated ear height.
    I removed the mdf pedestal and sealed the four anchoring screw holes in the bottom of the speaker cabinet. Then I replaced the mdf pedestal with a homemade one of solid oak, painted black to match the cabinets. The original pedestal was about 1" tall, the new oak one is 1-1/2" tall and is anchored very securely to the cabinet base by eight (two per side) screws.
    I used solid copper spikes that add just over 1-1/2" (including their essential height leveling nut/washer), bringing the cabinets to just over 3" off the ground, or an increase of a little more than 2" from their original height. The completed project looks very nice and is very stable. I currently have them on hardwood floors with protective floor discs below each spike.
    To my ears, they made a very noticeable sonic improvement to the 2Bs, especially on the bass response.
  • teekay0007
    edited January 2013
    Several people I'd contacted before doing my 2B's spikes had gone with the sold out ones ES listed above and they were not pleased with the fact that those spikes were too broad and the tip too rounded to get a good carpet piercing. I know that the OP currently has his speakers on a "no-pile" rug, but it may be of concern for future speaker placement (ie. thicker pile above a rubber pad) and he might want to shop for spikes with sharper tips.
  • teekay0007
    edited January 2013
    Here's what mine look like completed.
  • Spiffyfast
    Spiffyfast Posts: 35
    edited January 2013
    Been thinking of spiking my 2bs ... Anyone really experience a notable difference?
    Mains: Polk Audio SDA-2Bs
    Center and Surrounds: Bic Acoustech
    AVR: Pioneer 1015tx
    Amp: Anthem Amp 1
    Turntable: Project Debut III
    Inputs: Xbox 360, Samsung BDP-1000, Apple TV
    F1nut Posts: 50,829
    edited January 2013
    Spiffyfast wrote: »
    Do a search for spikes here. I don't think anyone that has added spikes didn't notice an immediate improvement.
    Toolfan66 Posts: 17,363
    edited January 2013
    "Spikes" a speakers way of saying "can you hear me now!!"
  • deronb1
    deronb1 Posts: 5,021
    edited January 2013
    I removed the bases on my 2Bs and drilled right into the speaker cab. Installed the inserts and screwed in the 1 5/8" Dayton brass spikes. Solid as a rock on berber carpet, and a nice improvement in both bass response and imaging (especially at lower volumes).
