Digital terminator for digital outputs?
audio_alan
Has anyone tried a "digital terminator" on their CD/SACD player?
http://www.ebay.com/itm/Digital-Enhancer-For-SACD-CD-Player-/121021072679?pt=US_Audio_Cable_Plugs_Jacks&hash=item1c2d6b0527
Any opinions on how well they work?
Post edited by audio_alan on
I know that jumping analog outputs is a bad idea because you are sending the output voltage back into the unit, and I would assume the same is true with a digital output. It may work for the inputs, but since the seller suggests using them on the output, I wouldn't trust him unless I'm missing something...
My Lector DCP came with a "digital terminator" installed and instructions to keep it in place when using the analog outputs. I have not experimented with it removed so I cannot comment on if there is any true sonic benefit.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Save your $20.They are just shunting the digital output to ground through a $.02 resistor.How this will improve the analog outputs is sheer audio mysticism IMO .
Yeah, I wasn't placing too much faith in it doing a whole lot. I don't hear people raving about it, so I think I'll just skip it. I was more curious to see if anyone had tried it and was like "YES, DO IT!" :eek: haha
