How do I attach pics?
kelley
kelley Posts: 287
I tried to attach a pic on one of my replys but it didn't show up. I went to the attach image block and transferred a pic from my desktop to the block, but when the message came up there was nothing. My pic is small enough. What am I doing wrong? Thanks
SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
  • dorokusai
    dorokusai Posts: 25,638
    edited November 2003
    Use the attach file option....browse to your location....select the file....and submit reply, you cannot preview it, or it will not work.
    That should hook you up.
  • Olanen
    Olanen Posts: 45
    First thing you have to do. Save as your current pic to jpeg format
    and make sure you will not save to more than 1024k.
    Now you will see your attached file.
    Enjoy.
  • kelley
    kelley Posts: 287
    Got it. Thanks to all.
