driver substitution
tomhoutx
tomhoutx Posts: 5
edited November 2003 in Speakers
I ordered a MH 6511 driver to replace the bad one in my SDA 1C. I was told that there were not any in stock but if I tried calling back every 3 or 4 days, they might receive some. Well today I received a MW 6501, sent from Polk. The speakers look and feel identical but there must be some difference. I'll call Polk in the morning when they are open and ask them but I thought I'd put the question to the group to see what the general thinking is.
Thanks,
Panasonic PT-B1010 Video Projector
Vidikron ET-100DS Line Doubler
Draper 100 inch Diagonal Screen
Yamaha A/V RX-V530 Dolby Pro Logic/Digital Matrix 6.1 375watt Amp
Panasonic AG-1970 S-VHS Recorder
Panasonic DVD-RV32 Player
Motorola DCT 2224 Digital Cable Conv
Polk SDA-1 L & R Main Speakers
Polk CSi40 Center Speaker
Polk R30 Rear L & R Speakers
Polk RSW202 Subwoofer
Post edited by tomhoutx on
    F1nut Posts: 52,243
    You meant that you needed a MW6511, right? The 6501 will get you by, but keep your eye out for the 6511 either from Polk, here or eBay.
  • tomhoutx
    tomhoutx Posts: 5
    Yes, I needed a 6511. Now that I've looked at them closer, I've noticed that the "red dot" indicating polarity is on the opposite side from the 6501. And with this particular SDC "cross connect" system, I wonder if mabe the polarity is to be switched for the reverse movement of the cone for the "canceling out" effect?
  • tomhoutx
    tomhoutx Posts: 5
    I said SDC above when I meant SDA.
    F1nut Posts: 52,243
    Tom,
    The MW6501 has been used for both the normal driver and the SDA driver. Why the red dot is on the other side......I don't know. Just hook the MW6501 up the way your MW6511 was.
  • madmax
    madmax Posts: 12,434
    You can be sure of the polarity if you want to test it. If you connect a battery to it with + of the battery going to + of the speaker the cone will move outward. I've always used a 9V battery for this test. Obviously if you have an original driver you can check it as well and make a comparison. I don't know whether the red dot is + or - but what is important is that it is wired in the same polarity as the old one.
    madmax
    Vinyl, the final frontier...
  • tomhoutx
    tomhoutx Posts: 5
    Well I talked to the factory and they said they made a mistake by shipping me the 6501. Helen said that the coil is designed differently and that I need to replace the 6511 with a 6511. The only thing is that they have none in stock but she told me to keep checking back with her every few days and they might get a shipment in. It seems strange that they don't know when a particular model of speaker is scheduled to go into production to replace empty stock. Helen did give me an RA so that I can return the 6501 for credit although I do have to pay for shipping. I did notice on the 6501 that it was stamped "made in Mexico" and I mentioned this to Helen. She told me that the speakers now being shipped are not made in Mexico. She did not mention where they are now being produced. Do you think maybe San Diego or perhaps Taiwan? (joke)
    thanks again,
  • hoosier21
    hoosier21 Posts: 4,428
    Polk shipped the wrong driver and you have to pay to send it back, that don't sound right.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
