FS: Polk Polkaudio CS250-S center channel speaker
Mystery
Mystery Posts: 2,546
edited January 2013 in For Sale (FS) Classifieds
For sale is a Polk Polkaudio CS250-S center channel speaker.
$45 + shipping.
In very good condition with minor scratch here and there.
Description of CS250-S center channel:
Home theater takes on a new dimension
The CS250 center channel speaker features:
Magnetically shielded to allow safe placement next to TVs and video monitors
Dynamic Balance drive units ensure timbre matching to other Polk speakers for seamless imaging
Fluid cooled tweeter provides the high power handling essential for center channel speakers
Non-metallic driver basket assures the best magnetic shielding
Angled cabinet allows the CS250 to be pointed upward when placed in a low position (such as under the TV)
Low profile design allows unobtrusive placement on top of TVs
The Center Channel Loudspeaker:
Whether you're assembling a new home theater system or upgrading an existing one, to experience the full potential of Surround Sound you will need a center channel loudspeaker.
Contrary to popular opinion, the center speaker is not just for reproducing dialog. Since all on-screen action, including explosions, gunshots and sound effects as well as dialog, must be faithfully reproduced and anchored to the TV screen, not just any speaker will do.
Here's a checklist of things to look for in a center channel speaker.
Designing a speaker to address all these criteria is a tall order. How do you build an uncolored high performance speaker capable of handling lots of power, magnetically shield it and then package it into a compact, unobtrusive enclosure? By applying the latest technological advances in materials and measurement to an understanding of people's needs, Polk has done exactly that in three new center channel loudspeakers. The Polk Audio CS150, the CS250S and the CS350LS.
Specifications:
Driver Complement
Tweeter
Quantity 1
Diameter 1" (2.54cm)
Type Dynamic Balance dome tweeter
Mid / Woofer
Quantity 2
Diameter 4 1/2" (11.43cm)
Electrical
Total Frequency Response 60Hz - 25kHz
Upper -3dB Limit 23 kHz
Lower -3dB Limit 80 Hz
Nominal Impedance 8 ohms
Efficiency 90 dB
Recommended Amplifier Power 10 - 150 watts per channel
Amplifier Specs
Amplifier Type 0
Dimensions
Cabinet Dimensions
Height 6" (15.24cm)
Width 18" (45.72cm)
Depth 8" (20.32cm)
Post edited by Mystery on
  • smglbrth
    smglbrth Posts: 1,496
    edited January 2013
    Good center channel, holds it's own pretty well for 4.5 inch drivers, had one years ago. If you would have posted this one day earlier I would have bought it. I just bought a CS2 Series II off Newegg. For your asking of $45 it's a good deal, IMO, for anyone else looking...
  • Mystery
    edited January 2013
    thanks.
    just sold it locally.
