Polk Audio Monitor70 Series II Floorstanding Loudspeaker
Juggalo23451
I am just wondering what their RMS rating is.
Thank you
I know this is their power rating 20-275W
Thank you
Computer builder and water cooler
res/mcp35x-rx480-gpu-gpu-rx480 white tubing
res/mcp35x-rx480cpu-chipset-res orange tubing
To the best of my understanding 20-275 watts is a range that tells you the minimum and maximum wattage these speakers will consume in order to operate. Speakers do not produce power, they consume it, so there's no RMS rating. They will eat what you feed them. The better fed they are, the better they will sound ;-)
I'm not expert thought, that's just my best interpretation.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
That is exactly right.:razz:Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
practically all speakers have an rms rating in what they can handle.
example
Audiobahn AW1251J sub
12" 500W RMS 4-Ohm Dual Voice Coil Natural Sound Subwoofer
tweeter
Audiobahn AT60J
Power Handling:100W RMS
talks about speakers and rms
http://www.bcae1.com/speakrat.htmComputer builder and water cooler
res/mcp35x-rx480cpu-chipset-res orange tubing -
Called polk audio and Tech support said 20-275w is the rms even though it is not listed on their site.Computer builder and water cooler
