What rears to get?
The Hun
Hello All.
I got a pair or RTiA9 for my fronts bi-amped, CSiA6 for my center channel and a 10 inch Boston Acoustics sub ASW 650 so far.
Now I am in the market for the rest of my 5.1.
Do you guys think that I should go for the RTiA5s or a pair of F/XiA6?
The space is not an issue, price wise it will cost about the same because I would have to get stands for the F/XiA6.
I got the system powered by an Pioneer Elite SC-65 receiver and a Panasonic TC-P60GT50 plasma.
Thanks for all the help
Post edited by The Hun on
Welcome!
F/XiA6. -
Thanks, I been a member since 2012 but never posted anything.
FX series will give you more of a 'surround sound' type as they are not pointed right at you. RT bookshelves will give you more directional sound.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Welcome. On my main HT rig I use some old Polks. RT2000p, you can look them up and notice they were once about $1k each and now be had for a couple of hundred a pair. Each tower has 2 8" powered sub-woofers which really add to the base experience, they can be moved around some and do not have to be mounted on the walls or placed on stands. Food for thought, and they are easy to power whereas the RTI a towers require substantial power which could put you over the top on your AVR power. Just my .02 worth.:rolleyes:Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
mdaudioguy wrote: »Welcome!
F/XiA6.
+1, F/XiA6 will serve the purpose._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Thanks for the advice, I will go for the F/XiA6.
Does anybody know what brand or type of speaker stands I should get that will complement the A6? -
Can't you mount them on the wall, they seem to work best in my situation mounted a little (two to three feet) my seated listening levelHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
i enjoy the monitor 70 series 2 for my rears
For the job that surrounds do, I think that RTia-1's would be more that sufficient.Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub -
How much do you Like your panasonic gt50 if you could do it all over again would u get a vt50
X100 on the F/XiA6, I just bought a pair and I LOVE them!
I love the Panasonic gt50, the reason that I dint go for the vt50 was simply the price. It was almost a grand more.
My friend has a vt50 55 inch and to tell you the truth its not worth the higher price.
The blacks might be a little darker and it has a single pane glass.
