SDA 1c's that need some help.
bored184
bored184 Posts: 324
edited January 2013 in Vintage Speakers
I was hoping my first post here would be a positive one after my purchase of my Polk Audio SDA 1c's. The problem is I have three stuck drivers due to magnet shift. I have read quite a bit about fixing these but I was wondering if anybody has any tips.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
Post edited by bored184 on
    Toolfan66 Posts: 17,333
    edited January 2013
    Call Polk and order 3 new drivers..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
    edited January 2013
    Oh and welcome to the forum..
    SVS SB16 X2
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2013
    Tell polk u r a member and u get a discount!!!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Schurkey
    Schurkey Posts: 2,104
    edited January 2013
    There's a helpful thread regarding building a fixture to re-center the magnet.
    http://www.polkaudio.com/forums/showthread.php?135716-Let-s-Try-to-Fix-a-MW6511-Damaged-in-Shipping...
    This became very relavent for me as I dropped a driver just before Christmas; I'll be repairing the magnet--pole piece on a 6509 in the next week or so.
    Everyone else uses epoxy, which to me is the wrong adhesive for this purpose. I'm using a substance that I'm familiar with from automotive work; high-strength thread-locking compound. (Red Loctite 271 or equivalent) Think of it as similar to super-glue. A thin-bodied adhesive that cures in the absence of air (anaerobic) and is readily available in any automotive parts store.
    http://www.amazon.com/Henkel-01-27100-Loctite-6-ml-Threadlocker/dp/B000FP8EUS/ref=sr_1_1?ie=UTF8&qid=1357408096&sr=8-1&keywords=Loctite+271
    The magnet is nicely bonded to the basket; but I don't have the pole piece centered and secured yet.
    F1nut Posts: 50,753
    edited January 2013
    Toolfan66 wrote: »
    ^This^
  • tophatjohnny
    tophatjohnny Posts: 4,182
    edited January 2013
    ^This^
    ^That^
    edited January 2013
    Schurkey wrote: »
    And when your done, if your lucky to get it centered, then you just hope it works and you haven't done any voice coil damage in the process..
    SVS SB16 X2
  • Malbec
    Malbec Posts: 554
    edited January 2013
    Schurkey, not sure if the red Loctite is best for your application.
    http://www.loctite.sg/sea/content_data/LT3273_Speaker_Assembly_Adhesives_Guide.pdf
    I've used the 271 as a thread locking adhesive only, so I don't know what the open time might be and if it would bond as needed.
    Loctite Depend 330 has given me good results with metal to metal bonding. You can use it for almost any surface.
    Also the U-05FL urathane adhesive works well. Loctite Black Max would be another option. Loctite is very specific on what adhesives to use for a particular application.
  • Schurkey
    edited January 2013
    Malbec wrote: »
    The magnet (so far) has stuck to the basket very well. Two or three drops is all it took.
    Cure time is about five minutes (wasn't watching the clock, but it got sticky and hard to move long before I got the pole piece centered; had to remove it and clean off the pole piece and magnet.)
    The primary advantage here is...I already own it.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited January 2013
    That's some good information.
    Malbec wrote: »
  • bored184
    bored184 Posts: 324
    edited January 2013
    I will try and get a photo up of the drivers but on the back they read, Polk Audio MW6510, Aug 1 1988, and stamped sda in red ink. Using my mm they read 6.6 ohms.
  • bored184
    bored184 Posts: 324
    edited January 2013
    Called Polk today and got three new drivers on order! I still plan on trying to fix the original but after talking to my father who is a machinist by trade we are going to design a jig out of aluminum. We have a prototype out of PVC that I will try out sometime soon. My plan is to document all this so hopefully others can learn from my mistakes.
  • PolkieMan
    edited January 2013
    How much $$$ each ?
    bored184 wrote: »
  • Saftgeek
    Saftgeek Posts: 114
    edited January 2013
    If you change your mind DO NOT throw the frozen drivers away. I'm a buyer. I have the jig and would love another go at unfreezing some drivers.
    Don't forget to take pictures and let us know how it goes. My only concern would be the amount of time it takes for the glue to set up... Five minutes is not much time.
    Good luck!
    Saftgeek-
  • bored184
    bored184 Posts: 324
    edited January 2013
    The new drivers were $48.00 a piece with free shipping, the forum memember discount is amazing! The gentlemen I talked to was really nice and was able to answer all of my questions. I was told these are direct replacements for the MW6510's and they have quite a few stock. I was told though to not run then hard and give them a chance to get broken in first. I also asked about doing a driver swap so that I had roughly (3 isnt a even number) the same number of new drivers on either side. I was told this to wasnt needed and was reminded to break them in gently. I will take photo when the new drivers come in and I will be doing my best to do a write up on the jig being designed and my progress at realigning the magnet.
  • Mystery
    Mystery Posts: 2,546
    edited January 2013
    Great!
    If/when you fix the frozen ones, you'll have backups for life.
    F1nut Posts: 50,753
    edited January 2013
    Make sure to trim the rubber around the screw holes before installing them otherwise the screw head will twist the rubber surround.
  • Schurkey
    edited January 2013
    bored184 wrote: »
    If this was me--and it "sort of" is, since I found a used original 6509 but don't know it's history--I'd put the new drivers in the SDA positions, and use the originals in the Stereo positions.
    bored184 wrote: »
    Man, there's a lot of that going around this time of year.
  • bored184
    bored184 Posts: 324
    edited January 2013
    Schurkey wrote: »
    Which ones are the SDA drivers? I havent slowed down enought to read that far :)
  • Mystery
    edited January 2013
    bored184 wrote: »
    Outside ones usually...
  • Malbec
    Malbec Posts: 554
    edited January 2013
    http://www.polkaudio.com/forums/showthread.php?55888-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-Stereo-Dimensional-Array(SDA)
    bored184, go to the second post of this link and pull up left and right channel wiring schematics for the 1c.
    It will show you what you need to know. You can't swap dimensional drivers for stereo drivers.
  • Schurkey
    edited January 2013
    Schurkey wrote: »
    But then the 1B uses identical MW drivers in all four locations per speaker--the 1C doesn't.
    bored184 wrote: »
    Mystery wrote: »
    SDA drivers are always "Outside ones", although in some cases not all outside drivers are SDA drivers.
    Malbec wrote: »
    Thanks for fixing my screwup. In this case, the MW6510s are the outside, SDA drivers; while the inner, Stereo drivers are MW6511s. I still had my mind calibrated to the 1B instead of the 1C, and you've taken care of that for me.
  • PolkieMan
    edited January 2013
    Why doesn't anybody download that SDA Handbook?
    Everything is there.
    Is something wrong with the site?
    It's a PDF file.
    http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
    It's going to look funny with only 3 new drivers instead of four, you'll see:cheesygrin:
    Original vintage MW6511's are hard to find, MW6510's not so much.
  • bored184
    bored184 Posts: 324
    edited January 2013
    PolkieMan wrote: »
    Just finished it. You are right everything is there. I will be printing it and going through it with a highlighter this weekened.
  • bored184
    bored184 Posts: 324
    edited January 2013
    Did a dry run using the pvc jig and it worked great. I was able to center the magnet with no problems. Tomorrow I will break out the jb weld. If all goes well, I will have the originals fixed by the time the replacements arrive.
  • bored184
    bored184 Posts: 324
    edited January 2013
    Here are a couple photos of the driver in and out of the jig.
    I have the second MW6510 curing in the jig now and tonight I will do the MW6511. So far things are going well. I would like to thank all you for your help. When its finished and cleaned up I will get some photos up.
  • PolkieMan
    edited January 2013
    You are doing a fine job saving the Made In USA originals which I just like the vintage I know the new ones are supposed to be just as good, maybe it's just me.
    Print out the SDA Handbook put it in sheet protectors and a binder.:cheesygrin:
    bored184 wrote: »
  • Schurkey
    edited January 2013
    PolkieMan wrote: »
    WERE the originals "Made in USA"?
    The paper label on the back of my spare SL2000 says "Designed and Engineered in the USA by Polk Audio Inc"; this leaves open the likelihood (I'd call it "guaranteed") that they were MADE somewhere else. Mexico seems likely...but I don't have evidence of that. It almost certainly was NOT China, the most reprehensible nation on the face of the Earth.
    The paper label on the back of my spare MW6509s don't even admit to that much. "Designed for the SRS 2" or something very similar.
    First Guess: The original drivers were imported, but from a higher-class of country (Non-Communist) than the current replacements. This may (or may not) affect the quality of the actual product, but I really resent improving the Communist Chinese economy while stabbing a knife into our own.
    Anything that can be done to reduce Chinese imports is fine by me--except trading "Made in China" for "Made in Viet Nam", or "Made in Cuba", etc.
  • PolkieMan
    edited January 2013
    You have a point, I stand corrected later ones where made in Mexico :neutral:
    I guess that's what suprised me also about the RDO 194/198 being better than the SL2000/3000
    especially the SL3000 cause so much time and effort was spent perfecting the 3000 to be so superior.
    The older drivers all had stickers on the back with dates and QC OK it kinda makes me wonder if the
    older MW were better maybe the SL3000 were too?
