Pebble E-Paper Watch for iPhone and Android
zingo
Did anyone invest in the Kickstarter for the Pebble watch? The Kickstarter is now closed and this is one of the highest funded project of all time on the site, but the Pebble website is currently taking $150 preorders. It seems like a great watch since it has a lot of the functionality of your current smart phone, but you could also get burned as it's not a current product, even though it's expected with high praise...
Pebble is the first watch built for the 21st century. It's infinitely customizable, with beautiful downloadable watchfaces and useful internet-connected apps. Pebble connects to iPhone and Android smartphones using Bluetooth, alerting you with a silent vibration to incoming calls, emails and messages. While designing Pebble, we strove to create a minimalist yet fashionable product that seamlessly blends into everyday life.
CUSTOMIZE WITH APPS
Apps bring Pebble to life. We're building some amazing apps for Pebble. Cyclists can use Pebble as a bike computer, accessing the GPS on your smartphone to display speed, distance and pace data. Runners get a similar set of data displayed on their wrist. Use the music control app to play, pause or skip tracks on your phone with the touch of a button. If you're a golfer, feel free to bring Pebble onto the course. We're working with Freecaddie to create a great golf rangefinder app for Pebble that works on over 25,000 courses world-wide. Instead of using your phone, view your current distance to the green right on your wrist. These apps will be the first, with more in the works!
CUSTOMIZE WITH WATCHFACES
Pebble can change instantly, thanks to its brilliant, outdoor-readable electronic-paper (e-paper) display. We've designed tons of watchfaces already, with more coming every day. Choose your favourite watchfaces using Pebble's iPhone or Android app. Then as the day progresses, effortlessly switch to the one that matches your mood, activity or outfit
BEAUTIFUL WATCHFACES
CUSTOMIZE WITH NOTIFICATIONS
If you need to stay on top of things, Pebble can help with vibrating notifications, messages and alerts. Dismiss a notification with a shake of your wrist. Don't worry, it's easy to disable all notifications.
Incoming Caller ID
Email (Gmail or any IMAP email account)
Calendar Alerts
Facebook Messages
Twitter
Weather Alerts
Silent vibrating alarm and timer
Android users can also receive Text Messages (SMS) on their Pebble. Unfortunately iPhone does not expose this data. Have any suggestions for other notification types? Send us a message!
Want your watch to tell you when your next bus is leaving? Maybe you're jonesing to see your compile status or recent github commits. Think push notifications, directly to your watch using the data connection on your phone. Want to check-in on your watch, or create an app that can monitor your sleep? Pebble can send data from the accelerometer and buttons back up to the internet.
Pebble can receive simple alerts and notifications from if this then that (ifttt.com) or our web-facing RESTful endpoint. More adventurous developers can use the Pebble SDK, with its Arduino-like abstractions and simple C structure, to gain full control of the watch. Multiple apps can run on Pebble, along side watchfaces and regular notifications.
Load apps using Bluetooth
144 x 168 pixel display black and white e-paper
Bluetooth 2.1+ EDR and 4.0 (Low Energy)
4 buttons
Vibrating motor
3 axis accelerometer with gesture detection
Distribute apps via Pebble watchapp store
Detailed SDK specs are available on our Pebble Dev Blog.
HOW IT WORKS
Pebble connects by Bluetooth to your iPhone or Android device. Setting up Pebble is as easy as downloading the Pebble app onto your phone. All software updates are wirelessly transmitted to your Pebble.
COMPATIBILITY
iPhone 3GS, 4, 4S, 5 or any iPod Touch with iOS 5 or iOS 6. Android devices running OS 2.3 and up. Works great with Android 4.0 (Ice Cream Sandwich)! Unfortunately Pebble does not work with Blackberry, Windows Phone 7, or Palm phones at this time.
CUSTOMIZE WITH APPS
Incoming Caller ID
Calendar Alerts
Facebook Messages
Weather Alerts
4 buttons
Vibrating motor
HOW IT WORKS
COMPATIBILITY
Post edited by zingo on
Anyone have one of these? Now that they have been out a bit, it seems like most of the bugs are worked out for iOS, and it might be a cool watch.
I've been looking at the Pebble Steel, waiting to see what / if Apple brings to market but am getting impatient and may pull the trigger soon.
