Will the CS1 match the Tsi300 speakers?
buckrogers
buckrogers Posts: 11
edited January 2013 in Speakers
Someone told me the CS1 was a really weak speaker, and that I should get the CS10. While I agree the CS10 is the bbest choice, I have a good deal on a CS1. Will the CS1 be a horrible choice? Right now I'm using a teeny little yamaha center channel that came off a htib someone gave me. Or should I just keep saving?
Thanks. The cs1 is $30.
Post edited by buckrogers on
    edited January 2013
    Welcome to Club Polk!
    There is really NOT a great difference between those two speakers, the specs are almost identical. The REAL difference is between the CS1 and CS2 which is similar to the difference between the CS10 and the CS20. It's the larger drivers in the higher models that make all the difference.
    You'd probably be OK with the CS1 even though it is not an aesthetic match for the TSI 300s?
    cnh
  • buckrogers
    edited January 2013
    Thanks. I don't care too much about the looks. They don't appear *that* different.
