Subwoofer and frequency response
glemay
glemay Posts: 574
I'm a little confused. On my Polk Audio PSW202 its frequency response is 40 - 200 Hz. What exactly does this mean? Does it mean it cannot go any lower than 40 Hz? Is this sub not cabaple of 30 Hz frequencies?
Please clarify this for me.
Gerald Lemay
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited November 2003
    Actually, per Polk's published specs the *overall* response is 40-200.
    What does that mean? Per Polks specs, the *overall* rating is usually the 10db downpoint. They use that point as the absolute end of any useable response that you can expect. I typically look at the 6db downpoint as being anything useable, but what do I know.
    The 3db downpoint on your sub is 45-180. This is a better guage of what you will actually be able to count on your sub doing for you. Room loaded (ie IN your room), and corner-loading in said room can give you a *little* more on the bottom end in response and spl.
    As far as the high end of the response, that will be defeatable with your receiver, or with the crossover control on the rear of the sub.
    IMO, the 202 is an entry level sub (well - lets say 'woofer in a box'), good for small rooms where small (micro) speakers are used, and demands for pant-waffling bass are non-existant. The 202 may also be used to add a little low-end punch / emphasis to smaller bookshelf speakers.
    Cheers,
    Russ
  • Tour2ma
    Tour2ma Posts: 10,177
    Overall FR is 40 - 200. the +/- 3 dB range is 45 to 180 Hz, a more
    useful spec...
    is there 0 output from your 202 at 30 Hz? No, but there is no usuable output there and there's very little below 45 Hz.
    More later,
    Tour...
    Vox Copuli
  • glemay
    glemay Posts: 574
    I know I've asked this same question, but I want as many opinions as possible. Should I use the PSW202 with my soon to come Paradigm PW-2200? I don't want to open the box if it is not a good idea. If I am wasting my time with the PSW202 I'm just going to try and sell it. But if it is worth a try, I will give it a shot.
    Main System:
    Second System:
  • RuSsMaN
    What are you running for you rears? Could it be used 'back there' via speaker (high) level connections?
    Got a bedroom, office, 2nd zone rig?
  • glemay
    glemay Posts: 574
    russman,
    I'm using Paradigm Micro V.3 in the rear. And the system is in my bedroom. I've got RTi70 up front and a Paradigm CC-170 V.3 as center. My receiver is a Denon AVR-1803.
    I've was thinking about using it back there, but would it not make a diffrence it was back there or up front hooked up via RCA cable, since the LFE are directed to the sub anyway?
    What should I do with it?
    Main System:
    Second System:
  • Early B.
    Early B. Posts: 7,900
    Sell it.
    If you decide to use it, you probably won't be happy with it and you'll end up getting rid of it anyway, especially for the setup you have. Use the proceeds of the sale towards a better quality sub.
    "God grooves with tubes."
  • glemay
    glemay Posts: 574
    Any other suggestions?
    Main System:
    Second System:
  • Airplay355
    Airplay355 Posts: 4,298
    try to sell it, unless you have another system some where that could use a little extra low end.
    i dont think that mixing those subs would give you anything you would like, you could always try it to remove any doubt. if i were you, i would sell it.
  • PolkThug
    PolkThug Posts: 7,532
    I'd sell it, or hook it up to your computer system.
    Regards,
    PolkThug
  • theear707
    theear707 Posts: 12
    edited December 2003
    Gerald,
    I would only use a 202 for a small PC setup with tiny sats,as the claimed lower end of 40Hz is still very optimistic.
    Subs should be rated full power and then measured,I am sure the 202 will be a good 10 to 12dB down at 40hz what it was at 80Hz.At full output
    Its not a serious HT sub and too boomy for music.
    Take a look at the PSW404 or 505,these are solid down to 31.5Hz and pack a serious punch.The woofers and amps are much more capable plus the caninets more solid.
    I use both the PSW404 and 505 with one of my PC's
    :p
    They sound great with Totem ROKK and Tabu speakers.No boom just clean bass.
    Dynaudio Contour main system,Klipsch RF HT system and PolkAudio PSW404/505 subs and RTi speakers used with main PC.Some Totem speakers too...and much more
  • walk
    walk Posts: 178
    They are going for $90-100 on ebay right now. I'm almost inclined to pick one up at that price. It's not much of an upgrade over my 8"/75W sub right now, but I suppose I could run both =)
    - Sony 50"A3000 SXRD; Onkyo TX-SR 805
    - Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
    - Velodyne CHT-12 subwoofer
  • PolkThug
    walk, they are $89.88 brand new at Nebraska Furniture Mart.
  • JDOGG
    JDOGG Posts: 433
    hey Glemay, how much are you paying for the PW-2200, and how much is the PW-2100?
    Panasonic VIERA 46" 1080p plasma
    Onkyo TX-SR805
    Klipsch RF-7(bi-amped)
    Klipsch RF-25
    Xbox 360 with HD DVD
    Playstation 3
    Cobalt Cable
  • glemay
    glemay Posts: 574
    For the PW-2200 around $1100 CDN with TAX I don't know about the PW-2100. What have you seen it for?
    Main System:
    Second System:
  • JDOGG
    JDOGG Posts: 433
    I was just wandering, how much is that US? I haven't seen any prices, I just search around the net.Don't go to much dealers, just Ultimate Electronics.:(
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • glemay
    glemay Posts: 574
    I think it is somewhere around $800 USD
    Main System:
    Second System:
  • racer4551
    racer4551 Posts: 373
    Glemay,if your interested i have a pw2200 for sale, email me with any questions.
    *HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
  • glemay
    glemay Posts: 574
    racer4551,
    I might be interrested. How much do you want? Is it the V.2 or V.3 can you post some pics of the sub? What is its condition and how old?
    Gerald Lemay
    Main System:
    Second System:
  • racer4551
    Glemay, the sub is about a year old and is in great shape,i am not sure how to tell what version it is? It was purchased from an authorized dealer by me and have all the original packaging and box.If you look at my pictures in showcase you can see a front shot, i could email you more pics if interested.The price is 400.00 plus shipping.
  • gatemplin
    gatemplin Posts: 1,595
    On the back of the sub there is a white label with the model and version.
    Graham
  • racer4551
    I looked on the back of sub and there is a little white tag which gives the model no. as pw2200 and serial no. but that is all i see
  • glemay
    glemay Posts: 574
    Does it have the 400 watt RMS / 1500 watt peak amp or the 250 watt RMS / 750 watt peak amp?
    Main System:
    Second System:
  • racer4551
    I am not sure but being a year old i bet it has the 250 amp.
  • glemay
    glemay Posts: 574
    what would shipping be?
    My addresse is
    10 Adams Lane
    LaSalle, Ontario, Canada
    N9J 1R4
    Where about are you located?
    Main System:
    Second System:
  • racer4551
    From my area code 44662(navarre,ohio) to you at 75lbs shipping weight,ups ground,60.00.includes insurance
  • glemay
    glemay Posts: 574
    racer4551,
    Would I have to pay taxes on the Pw-2200 ro bring it into the country?
    Main System:
    Second System:
  • racer4551
    Not sure, anyone know? might have to contact ups,i sold a playstation to someone in canada and was told to ship as a gift to his son?
  • racer4551
    I just spoke to someone at ups and they told me you should contact customs and find out what it would cost to receive or if there would be any costs if it was a gift.
  • glemay
    glemay Posts: 574
    racer4551,
    I'm pretty sure I will have to pay taxes:( which will bring around $700 CDN. This is a little pricey since I can get the V.3 for just under $1000 CDN brand new. Sorry, just isn't the deal for me since I'm in Canada but for someone in the USA it must be one heck of a deal. Thanks anyway.
    Good Luck
    Main System:
    Second System:
