monitor 5 listend distance
canadianicon25
canadianicon25 Posts: 200
edited January 2013 in Vintage Speakers
i did a search to see if this has been discussed before but i didn't find anything.
for those of you who have monitor 5 polks what have you found to be an ideal listening distance from them? mine are with peerless tweeters.
Post edited by canadianicon25 on
    F1nut Posts: 50,753
    edited January 2013
    That distance will depend on how far apart the speakers are, so there is no one size fits all answer.
  • canadianicon25
    edited January 2013
    is there a 'formula' of any sort?
  • decal
    decal Posts: 3,205
    edited January 2013
    Your ears will tell you when you have the correct "formula". Trust them.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited January 2013
    Yes you need to know how far apart that they are.
    The distance between the speakers is related to the distance from them.
    Speaker placement is a matter of personal preference as well as a matter of acoustics the best three dimensional imagery will be obtained with speakers placed far from the walls and corners.
    With speakers aimed directly at the listener this position will be 8 to 14 feet from the speakers with the speakers separated by at least 6 to 8 feet.
    http://www.hifiengine.com/library/polk-audio/monitor-5b.shtml
  • canadianicon25
    edited January 2013
    thanks to all of you. the numbers will give me a place to start. i will tweak from there until my ears are happy.
