Monitor 75T
Loved the specs on this speaker to use as my fronts so I ordered them and to my surprise the woofers are 5.5" not 6.5". Which one should it be ?
Are you measuring to the edge of the rubber surrounds?Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
Yes, outside edge of rubber to the other outside edge is 5.5"
That can't be right. There's four per cabinet right?Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Yep plus tweeter, the width of the cabinet is 8.25".
Sounds like the M70 and M60 got a little too cozy in the manufacturers work shop, hmmmmMarantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
There is 6 screws that hold each woofer in place. From centre to centre of the screw on either side of the woofer is 6.5". I hope Polk is not calling that the size.
I wouldn't think so. I went measured my drivers. My mids are spec'd at 5.5 and actually measure 5.25. My woofs are spec'd at 7" and actually measure 6.75 and that's the actual driver not the mounting bracket.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
I'd get ahold of Polk and just ask. Of course tact is everything, there must be a logical explanation in it somewhere.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
Yea, I emailed them about it because I bought 4 of them & asked them if they could reply with any solutions. Like you said tact is everything. I was going to buy a new centre but nervous now. Lol
My m70s measure 5.5in and m60s 4.5-ish, so yours seems right.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
Well then it sounds like Polk is advertising false info, I wonder what people think about that ?
6.5" is the dia of the entire driver assembly. They're all like that.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
jeremymarcinko wrote: »6.5" is the dia of the entire driver assembly. They're all like that.
That would explain the 6.5" from centre to centre of the mounting screws. THANKS, I did not know that & will take that into consideration the next time. :cool: -
I measured my LSi and they are as spec'd not including the screws.
Hey, so i emailed Polk and they responded to measure the 'basket' of the driver. And it measures to 6 1/2".
