SDA-SRS speakers and a Yahama RS700
Can someone tell me if the Yamaha RS700 receiver is a common ground receiver? I am also looking to purchase the missing interconnect cable and was wondering what I needed to know to tell Polk which type of interconnect wire I needed to purchase. Would I be able to find this out from the Serial Number? I don't believe any sort of upgrades or modifications have been done to these as my aunt was original owner.
I am also assuming I can set the Yamaha RS700 to low impedance when using a bi-wire set up. Is that correct? I just wanted to make sure before I did so I didn't blow up my new receiver or speakers.
test
The interconnect cable can be made: http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=248760&
