Spiking 2Bs
deronb1
deronb1 Posts: 5,021
edited January 2013 in DIY, Mods & Tweaks
I am spiking my 2Bs right now with 1 3/8" Dayton brass spikes. I removed the bottom riser and will be drilling soon (as soon as my battery charges). Should I put these right in the carpet, or use the cups too. I have an 18" x 18" x 1" piece of oak to put them on, but would rather just put in carpet for WAF. Any thoughts? Will it sound pretty much the same either way?
    VR3 Posts: 29,762
    edited December 2012
    Unless you are spiking the wood block I would just go straight to the carpet
  • deronb1
    VR3 wrote: »
    Cool...not spiking the wood, just the speakers. Thanks Trey.
    F1nut Posts: 52,406
    I concur, spikes thru the carpet.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited January 2013
    Let me know if you notice a change in the sound!
  • deronb1
    edited January 2013
    I have noticed a tighter bass response, especially at lower volumes. Glad I did it!
  • sda2mike
    sda2mike Posts: 3,131
    edited January 2013
    one of the best mods you can do
  • smglbrth
    smglbrth Posts: 1,506
    edited January 2013
    I believe the cups that come with those are for "nice" hardwood floors and such. Make sure you hang onto them though, I lost most of mine in a move when I didn't use them, then once I had a need for them...
