RTI10 Front Speaker Distance
dirtydenim86
I was wondering how far away I should be from my RTI10 Front Tower Speakers?
I just pick them up haven't gotten all my pieces yet so I haven't installed them my basement isn't the greatest setup for a Home Theater system but i will be approximately 8FT from the speakers is this fine?
Onkyo TX-NR809
RTI10 Polk Audio Front Tower Speakers
RTI4 Polk Audio Bookself
CSi5 Center Channel RTI Series
PSW505 12" Subwoofer
How far apart are they? That's how far away you should sit. In other words, you and the fronts should form an equilateral triangle.My humble setup...
...is no more.
Good to know!Onkyo TX-NR809
PSW505 12" Subwoofer -
I think when it comes to distance, your viewing distance from the flat panel is the first consideration. Then the location of your speakers come next and of course, the room always plays a big factor.
If the RTi's are anything like the RTiA's, then they like to have some room around them and not shoved against the wall or in a corner.
I view a 64" wall mounted plasma, sit 12' from it. My A9's are 9' apart and toed in and 11' from viewing distance. I have the rear of the mains elevated by 1/2" so that puts the bottom of the speaker 14" from the wall and the top is 18" from the wall. I prefer them a couple of feet from the wall but this room I'm in doesn't permit. Of course, I'm in between dedicated theater rooms
Anyway, there's my nickles worth of dollar advice.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2
