bass & room
dholmes
dholmes Posts: 1,136
Wasnt there a theory on bass & room size?? This paper if Im correct stated that a room say 20x12 could only support bass down to 30hz, no matter what sub you used!Does this make any sense to anyone ? let me know thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • Airplay355
    Airplay355 Posts: 4,298
    edited November 2003
    i dont think that it's true, then everyone would have to have small HT rooms, and 20 x 12 is not that big, my room is a bedroom and it 15 x 11. ill wait for doc to chime in but i dont think its true, or tleast if it is i never knew it was.
  • gatemplin
    gatemplin Posts: 1,595
    It is not true. Maybe it had something to do with standing waves in small rooms occuring usually above 30 Hz or something like that.
    Graham
  • John K.
    John K. Posts: 822
    No, what you read was incorrect, in fact it's more nearly the opposite. The smaller the listening space, the easier it is to get strong and extended low bass. A big room doesn't "support" bass. An example is the bass pressure build up inside the relatively small room in a car which allows for very low and loud bass. Another is the good bass which is achieved with some headphones with their "room" only an inch or so long.
  • dholmes
    Dr. Spec, input please
  • PolkThug
    PolkThug Posts: 7,532
    Yes, the car is a good example. I can definitely hit below 30hz in my small car space.
