Power Bars
Fireman99
Just wondering if anyone uses a protected power bar for their amps, etc or plug the amps directly into the wall outlet?
Dan
Dan
Recever AVR 8000
Amp PA 4000
CDR 26
Mains RTI 150 Bi wired
Center CSI 40 Bi wired
Surround FXI 30
Rear RTI 4
Sub PSW 140
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140
Post edited by Fireman99 on
Directly into the wall for me.
I have an aftermarket power cord and it would defeat the purpose if I plugged into a powerbar.
I plug my receiver into a powerbar only because I'm out of plugins.
SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
I'm using RCA Performance Series surge protector in Black colour.Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
Monster Cable HTS5100. I am weird about that issue, so I bought one to feel better.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yeah I use one. The primary reason is surge protection. We get a lot of lightening around here so anything that may prevent turning my gear into a smolder pile of ash is a good thing. Keep in mind that most surge protectors come with a certain amount of "insurance coverage" to repair or replace your gear if the surge protector fails to do it's job and your stuff gets damaged as a result.
I'm running one a s well I was just wondering if there was a power gain or Noise reduction if I went straight to the wall. I got $50,000 worth of coverage with my power bar. It Surge protects Cable T.V. Sat. and all the outlets I could need for the HT unit.
DanRecever AVR 8000
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
I don't think it's worth the risk of plugging your AV equipment directly into the wall. The cost of a decent surge protector is so small compared to the risk. Get one that has isolated filters. It'll help clean the line and you may experience a slight improvement in the sound/video as a result.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
My rig is sporting a Panamax 5100, care of the cool hook-up deal from Greg in the Flea Market....a $3000 rig needs more than a $20 Wal-Mart WOODS Brand "power strip". Most of the decent ones have "high-current" outlets designed for AMPS and it won't choke the current load resulting maximum power unlike the mediocre performance you'd get with a $20 "strip". Get one and don't look back. You'll be kicking yourself in the **** that one day when the power goes on the blink and all your gear goes up in smoke like Cheech-n-Chong.....
TonyDamn....8 lines...I've gotta put my sig on a diet now.... -
Fireman99,
Tony has a very good piont. You need a surge/power conditioner with a high power outlet. You could also look at the richard grey 400 or 600 units. You dont want to choke the power flow to your amp. Most power bars even the ones from monster do not have a high power outlet. Even the richard grey units says to plug in your 400 or 600 into one side of the outlet & the other side plug in your amp or for better protection into one of the rg outlets. We sell a number of Monster 3600, 5100, & 7000 's which has a dedicated high power outlet. What your looking for wont be inexpensive but get a good one that will work for you now & with future upgrades. -
I will add that the secure feeling that I get with mine, is worth every penny. I don't dance around in my beer can suit, chanting for lightning strikes....but I do watch movies and tv during storms with little worry.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I like the dancing bit!! That was a great little pick me up laugh after work!
DanRecever AVR 8000
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
All my gear including the subs are on power conditionners.
I use two Chang Lightspeed 6400MKII AC cleaners/power bars,three PS Audio outlet AC cleaners,one Monster AVS2000 voltage stabilizer,HTS5100 power center.
Just a few high power amps are conected directly,never had any problems.Dynaudio Contour main system,Klipsch RF HT system and PolkAudio PSW404/505 subs and RTi speakers used with main PC.Some Totem speakers too...and much more -
why is that? does the aftermarket power cord provide surge protection? does the aftermarket power cord "condition" the power?
just wondering, i don't understand why you can't use an aftermarket power cord with a power bar. which is better, an aftermarket power cord or the super expensive power conditions offered by monster and such? -
If I plug the power cord into a power bar, my system sounds dull and lifeless. Straight into the wall and clarity, imaging and soundstaging all improves. I don't have a very high quality power bar. I take my chances in terms of surges, knock on wood, I also live in one of the sunniest cities in Ontario.
I don't have experience with power conditioners simply because of the cost of them. I'm sure the high quality ones have their benefits.
You're not going to like this,
I can't explain it exactly, but putting a cheap powerbar in between the wall and my power cord would (forgive my non-EE techno babble;)) sort of choke the flow and introduce it's own signature to the sound.
I moved Nov 1st, plugged everything into a powerbar because my cables wouldn't reach the outlet in the wall and that's when I noticed a newly introduced dullness in my system. I moved things around a little to be able to plug directly into the wall again and voila it was back to normal. The only thing I changed was taking the powerbar out.
I'm not sure if this answers your questions thought.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
yes, you answered my question. i was just wondering if there was some inherent reason why the two shouldn't be used together.
and i don't mind the non-gEEk answer
if it made a difference to you, then that's what's important. -
dcarlson - Yeah, I also use two aftermarket power cords and take the risk of direct/in wall connect. Knock on wood indeed.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
