Need Coaxial cable:::
sgtgto
sgtgto Posts: 310
edited December 2001 in Technical/Setup
Hi:
Can someone help me out? I need a 24ft coaxial cable.
Gary:D
Post edited by sgtgto on
  • dwnopep97
    dwnopep97 Posts: 25
    Well there is a cheap solution to your problem. Goto your audio video store and get some good 14ga RG6. Make sure they put good ends on it and buy yourself some f to rca connectors. It isnt the best way but you get the length you need and since it is a digital signal anyways the sound shouldnt change all that much as long as the shielding is good and the ends are attached properly.
    System Includes:
    Yamaha Rx-V1
    Carver TFM- 42 on the Mains
    Carver M4.0t on Center
    Toshiba SD-3109 DVD Player
    Mitsubishi S-VHS Player
    Toshiba 43in Television
    MAINS- Polk Audio RT-55i
    CENTER- Polk Audio CS1000p
    SURROUNDS- Polk Audio FX-1000
    SUBWOOFER- Polk Audio PSW-650
    Nordost Silver Coax digital cable
    Audioquest Type 4 Bi-Wired
    Wanting:
    RT-3000p: Please send email if wanting to sell!
    Fx-1000
    CS-400i
