Passing a wire when disaster strikes...
joeparaski
So I decided to finally install the fancy pants HDMI wire to my projector. Using clips and screws I ran the wire neatly along the ceiling of my man cave when I pierced a water pipe! Needless to say I was horrified....water gushing out down the wall, on the carpet and on me. I rushed to shut off the main water valve which was in the back room, behind the tool box, behind the storage shelves....accessible only be lying down on my back and reaching under the shelving to the valve at the lower part of the wall.
Of course the only thing going through my mind during this time is how much damage is there gonna be and is the spray getting worse and is it spraying on my gear?
With the valve finally closed I rush back grabbing a bucket and towel along the way. The water spray had stopped and luckily had not touched my gear.
The cleanup process is underway.
Moral of the story....I'm not sure. I'm too depressed right now.
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
Moral of the story..... Water shut off valve should be readily accessible.If you can't hear a difference, don't waste your money.
+1 ^ Always have a clear path to ALL shut off valves.
I've got a deal with my water. I dont go where its at and it doesn't come where I'm at. Sounds like you have a mess. This is three Polkies with water issues and one with a furnace dead. Ya'll be careful out there.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
IME [not mine, I was the guy who did the restoration], you might want to add that one may want to know where they are to begin with.
Joe, best of luck for a quick and painless recovery with no anger from the audio Gods.
I feel for you my man. My Mom's house flooded Thanksgiving night and she didn't find it til the next evening. Over $22.000 in damages !!!! We are in the process of putting it back together now.If you can't hear a difference, don't waste your money.
This may be a good reminder for all of us to check the hoses on the washing machine and clean the lint from inside the dryer plus change the battery in the smoke alarms.>
Yikes man... that's rough. How long were the screws? That's very unfortunate. Sometimes stuff is real tight above a ceiling in a basement area.
Good luck with the clean up. -
What am I missing here ? How do you pierce a water pipe securing a wire to the ceiling ? Did you use 2 inch long screws ?HT SYSTEM-
lsi 9's -
Here is a picture with the section of pipe replaced with plastic piping.Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
That's seems to be how things go, if you were looking for that water line you would have had a heck of a time finding it.
What luck! FWIW...At least you know where your water line is now!
Just curious big guy, the copper pipe is a flat end that needs to be sweated, but it looks like you have a threaded end on the plastic pipe. How did you make that connection ?HT SYSTEM-
lsi 9's -
Tony, I think he used a product by sharkbite (or a similar brand). Designed to make copper repairs easier without having to sweat new fittings. Personally, I prefer to replace copper with copper but not everyone is comfortable using a torch up in their ceiling. It can be unnerving.
Joe, glad to hear you equipment was safe. It could have been a lot worse.For rig details, see my profile. Nothing here anymore... -
sharks bites are di-electric and you get no corrosion from electrolysis, no harm in using them for repairs/installs, but the are a loose fitting, whatever you connect will be able to spin, so if you have something with threads, you need pipe coming from a sweated joint, me and my old man learned the hard way when we tried to put a low cost shower spigot in, only to have the pipe spinning as we tried to thread to the adapter on the end, now that i am an actual plumber and can sweat a pipe i may re-do that for him
sharks do fail at a a lower pressure than sweated, but even so you will never have the kind of pressure to break one, also sweating in a ceiling is not a huge threat if you tack up some flashing as a heat shield
also happy your gear was unaffected2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know "WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Every month "The Family Handyman" magazine has a page of "Great Goofs" stories. They pay $100 for each story that gets published.
Man I feel for you, good luck.
We use that PEX style piping all the time at work to repair old pipes and it's great. It beats standard PVC any day, and they do have very easy and secure connectors these days.
Good luck with the clean-up! -
Bummer but glad you saved the gear.
You should do like Pepster and keep all of your plumbing in a small shed out in the backyard.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!!
