Bi Amp
Fireman99
Having never hooked up multiple amps (together) before I was just wondering. Once i send the preamp signal from the recever to the amp does the recever control the volume on the 2nd amp or do you need to use two volume controls?
Dan
I'm thinking the Recever controls it but not sure.
Dan
Recever AVR 8000
Amp PA 4000
CDR 26
Mains RTI 150 Bi wired
Center CSI 40 Bi wired
Surround FXI 30
Rear RTI 4
Sub PSW 140
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140
Post edited by Fireman99 on
use of pre-outs puts the pre in control of the external amp.More later,
Tour...
Vox Copuli
Thanx Tour that is what I thought but wasnt 100% sure so it doesnt hurt to ask
DanRecever AVR 8000
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
no problem... question is whether pre will coincidentally supply both the internal and external amps at same time... most do...More later,
Tour...
Vox Copuli
