Why this does not stop..........
Irrenhaus
So I got a pair of Linn Keilidh for stereo only was planing to use my current AVR the 709 and one of the amps's.
Now I find myself looking for a nice preamp to use it with the Parasound for the linn's so I dont have to be changing cables every time I want to listening to music.
I will use the Oppo as the source, looking at Emotiva, Adcom, Halo and Marantz preamps and others. Damm is it not easy to stop once you start............is therr a place for us like AA....LOL
Cheers
Irren
Cheers
Irren
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
It's called the rabbit hole. Welcome.
Yep most of us are full pledged members of said rabbit hole, another welcome, enjoy your lengthy visit.Home Theater
The Rabbit Hole is like my wife! I Hate,and love em both at the same time! Welcome home young man!!!! And Good Luck!!!!!"Everything I ever did in my life worthwhile I caught hell for"
bobsauto49 wrote: »The Rabbit Hole is like my wife! I Hate,and love em both at the same time! Welcome home young man!!!! And Good Luck!!!!!
Hey thanks for the young man part. I guess I will love the rabbit hole just have to keep digging and make it bigger.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
All you can do now is enjoy the ride.Damm is it not easy to stop once you start............is therr a place for us like AA....LOL
Dan -
Agree! never end. Thought I will stop after added a xpa-5. But already start looking for upgrade my free RCA cables. I just ordered some RCA plugs ( http://www.ebay.com/itm/180650392229?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649) and some RCA cables from Monoprice http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10249&cs_id=1024901&p_id=5978&seq=1&format=2 .MAIN:
Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Receiver- Harman Kardon Avr 3700,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
Sounds like you are.... easy to please but hard to satisfy....:razz: I know I amPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I love it!!!! Don't know much about it though, but the members here are great about helping and more than friendly!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Everybody here loves to spend someone else's moneyHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I keep telling myself I'm happy but then the itch comes back.
The only way stop ur itchy is stop come in here. But can't with more than a day. Admin can you set up more rule like FS section?MAIN:
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
Im happy with my Marantz. I also like my Rotel. B&K makes a solid preamp.
You should look at B&KB&W CM9Classé Sigma -
Started with a pair of speakers, turned into my first basic modding of said speakers, my first tube amp, and now I'm on the hunt for a tube pre-amp and a DAC .... The itch is tough to keep scratchedMains: Polk Audio SDA-2Bs
Center and Surrounds: Bic Acoustech
AVR: Pioneer 1015tx
Amp: Anthem Amp 1
Turntable: Project Debut III
Inputs: Xbox 360, Samsung BDP-1000, Apple TV -
Just as addictive as crack just not as hard on the body or illegle.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Actually even death dosent stop it, as i have designed a solar powered 2ch system for my coffin. However upgradesay come to an end.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
