SDA Update
oldrocker
oldrocker Posts: 2,590
edited December 2012 in Vintage Speakers
SDA-SRS Re-fab going ok, stain almost right, covers tight, crown amp in, parasound pre amp in, sounds ok, considering a psound F210 EQ and still working on the interconnect cable. Just time and money.
Post edited by oldrocker on
    F1nut Posts: 50,753
    Instead of the EQ, replace the crown with a Parasound amp.
  • oldrocker
    Idea on a good parasound amp? Still wants the eq capability.
  • oldrocker
    Also considering some sort of sub system, yes the sda's have good bass but looking for that extra "deep thump".
  • michael1947
    michael1947 Posts: 775
    Hmm, I dono bout a pro amp...how bout some photos.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • dpowell
    dpowell Posts: 3,068
    +1! A Parasound Halo would be a good choice. A21 or A23 depending on budget.
    If the Halo's are too pricey, consider some of the older models such as the HCA1200 II. It put out 200+WPC. The Halos will give you better detail though.
    I've also heard a Sunfire on my SDA's and it was remarkably similar to the Parasound. Maybe a bit more thump in the bass section where the Parasound did better in the highs.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
