set up disc help? (DVE)
mccarts747
mccarts747 Posts: 48
Does anyone have the Onkyo TX-sr600? and have they calibrated it using the new DVE disc and a SPL meter.
I have the disc and just picked up the meter. I went throught the disc once and the instuctions were non existent. I get the general idea of what i am supposed to do, however, i could use some help.
In the reference section there are two sets of test tones 'limited' and 'full bandwidth' which did you use and why?
This question is receiver specific but, how did you go about changing the speaker levels as you wnt through the test tones. There is a button that lets you do this but it is only a temp change. do i have to write it down and go into setup later?
what about calibrating for digital cable on video one or even the cd player? do you go into each mode and recalibrate those or?
any help would be great...
:confused:
Shawn
___________
Onkyo TX-NR609 (receiver)
Sony Blue ray Player
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
Cambridge Soundworks Cube8 (sub)
