Best Speakers for NAD C372
ss2504
ss2504 Posts: 2
edited December 2012 in 2 Channel Audio
Which speakers are best suited for NAD C372. LSI-25 or A-9 or Monitor-75. Mostly listen to Jazz and classic rock.
Post edited by ss2504 on
    tonyb Posts: 33,068
    Of the ones you listed, A9's.....but personally, I wouldn't pick any of them. The newer lsim series bookies and a good subwoofer from SVS, Hsu, Epik, Rel, Velodyne, etc, will be yards better for music. The older lsi 15's would also be good over your picks. Lots depends on your room too, associated gear.
  • ss2504
    ss2504 Posts: 2
    tonyb wrote: »
    @ tonyb - don't have budget for new LSIM - also it seems you prefer lsi 15's over lsi 25's - why? Is NAD C372 not powerful enough to drive lsi 25's? Thank you for your help
