Driving them SDA 1B's (which would you prefer and why?)
tophatjohnny
tophatjohnny Posts: 4,189
edited December 2012 in Vintage Speakers
Hey all. I am currently using the Onkyo TX SR805 to run my 1B's and am thinking of either adding a Parasound HCA1200 amp or change out to the Yamaha CR2040. While the Yamaha receiver only has 120 wpc I am reading that this 120 watts are more powerful than the 130 WPC that the Onkyo delivers?? What I do know is that I like it a little louder at times than the Onkyo will permit, as it goes into protection when I crank it up to where I want it sometimes, and only occasionally do I need that kick..but to no avail if it shuts down!! I am told that the Yamaha will not do that and the sound will be more powerful?? Hard to understand that if the watts are 10 less, but I am open minded to it. The idea of adding a amp is tough, as there is nowhere to place it as I see it now?? I'm sure the majority will say the amp is the way to go, so looking to see both sides of opinions and or suggestions. Thanks and I haven't been steered wrong yet,,no matter how brutal at times...(you know who you are TB) :smile: Thanks and Merry Christmas everyone. Great group here, that's for sure!
THJ
Post edited by tophatjohnny on
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Id go Parasound Johnny,one of the best upgrades for me was adding a amp.More punch all around.
    Dan
    treitz3 Posts: 20,121
    Merry Christmas to you as well, THJ. Have you ever considered going with a tube amplifier?
  • tophatjohnny
    Oldfatdogs wrote: »
    Dan
    Thanks Dan. I hope the amp option will be available when I am ready next week as I have not heard back from the seller with my offer as of yet. Christmas and family have people tied up and I understand that. The Yamaha receiver is priced the same as the amp, so let's see which one I end up with. Maybe neither...right?? Merry Christmas to you and your family Dan!
    Johnny
  • halo71
    halo71 Posts: 4,638
    --Gary--
  • tophatjohnny
    treitz3 wrote: »
    Don't know a whole lot about tube amps Tom, besides I hear they sound great! When I get back to my house tonight I will give the Onk an honest listen once again. Kinda up in the air right now.
    Fair enough. I know full well that a tube amp wasn't one of your two choices but from experience, the highly modified SDA 1C's I had sounded rather fantastic [the best I had ever experienced] on a tube amplifier. Just thought I'd throw that option out there to consider.
  • deronb1
    deronb1 Posts: 5,021
    Johnny, does your Onk have pre outs? I cant remember. If so, I can bring over the 555, and you can see if 200 wpc is gonna do it for those 1Bs.
    pitdogg2 Posts: 27,333
    Forget any receiver think AMP only no receiver will do them any justice
  • Schurkey
    Schurkey Posts: 2,122
    If those are the two choices, jump on the Parasound; ignore the Yamaha.
    http://www.classic-audio.com/yamaha-cr2040-p-307.html
    Yamaha rated at 120 watts into 8 ohms, but only 140 into 4 ohms. (IHF method) I'd call the Yammie amperage-limited. The 1B is a nominal 4-ohm load.
    By comparison, the Parasound HCA1200 is rated for 200 watts into 8 ohms (not all that much "louder" than 120 watts--you'll want to do some research on converting "watts" to "dbw"), but the rating into 4 ohms is a full 150% more than the 8-ohm rating--300 watts. The amp is less amperage-limited than the Yammie. 1Bs will appreciate this.
    http://www.parasound.com/pdfs/vintage/hca1200om.pdf
    Almost certainly the difference between rated power into 8-ohm load versus rated power into 4-ohm load. If you maintain the same voltage, the current required doubles when driving the 4-ohm load. If the Onkyo isn't rated into a 4-ohm load, (and that's the way I remember it being described--8-ohm specs and 6-ohm specs, but no rating for 4-ohm power output) it's going to mess the bed when you run it into a 4-ohm nominal speaker and turn the volume up.
    You have entered the 4-ohm speaker arena. 8-ohm rated power specs are now all but meaningless.
    Keep in mind that both of those options are old enough to perhaps need service work--a "tune up" if nothing else. Lord knows my old JVC receiver got quirky as it aged.
  • PolkieMan
    PolkieMan Posts: 2,446
    Is the 805 getting hot? You know I drive my 2.3tls with an 808. It doesn't get hot it sits on top of a wood stand nothing on top. I have a Carver TFM-25 that I used to use when I had a separate preamp Carver CT17. When I got the 808 I hooked them up they sounded great so I said why bother, but the 2.3tls are 8 ohm compatible.
    If I was going to buy a new amp it would have to do with how much money I have or wanted to spend but I would buy a new one and it would be 300 wpc.
    Just remember that driving 4 ohms speakers will make it run hotter and that may be why your shutting down. It's hot in Texas and I have a receiver out in the garage with a 120mm computer fan on top, heat is the silent killer.
  • tophatjohnny
    deronb1 wrote: »
    Thanks and That would be great. I don't have the correct cables to connect the amp to the receiver, so would need those as well. Just say when and i'll be ready!
    PolkieMan wrote: »
    Not sure what the Onkyo is set for 8-6 or 4 ohm?? Maybe that's the problem?? Thanks
  • cincycat13
    cincycat13 Posts: 887
    THJ,
    Do you have your 805 connected to a TV? You can go into the set up menu and see if the 805 is set for the lower ohm rating. I have the 876...which is very similar to the 805. When the 876 detected my 4 ohm speakers, it essentially self limits the power output so the 1xx watt rating is cut to around 55 - 60 wpc from what I remember. So I don't think you are getting 130. This is why I really wanted the amp you had which was designed for 4 ohm rather than limiting output for 4 ohm, but also like you...had ZERO idea how to fit it in physically or even worse...find an electrical source. So I am trying the onkyo 5007.
    Hooking up with deronb1 will give you your answer. Have fun!
  • deronb1
    I bring some cables. After the storm passes through! Merry Christmas!
  • tophatjohnny
    cincycat13 wrote: »
    THJ,
    can't find where to change the OHM on the receiver menu??
  • deronb1
    Actually, I think the 555 is closer to 300wpc at 4 ohms.
  • tophatjohnny
    Schurkey wrote: »
    The onk was set to 6 ohm(didn't see a 8 ohm option) and now set to 4 ohm and man, what a change. Blasting right now and not shutting down?? Love it.
  • PolkieMan
    Sometimes you find what you have will work you just have to dig a little deeper.
    How loud are you playing that thing?
    Are you one of those guys that sound like they are at the front door but they are over on the next block?
    If so start watching ebay on buy a couple of extra driver when you see them show up :cheesygrin:
  • tophatjohnny
    PolkieMan wrote: »
    Oh, you mean I'll start blowing them?? I'll tame it down a little!!
