Trigger wire???
snake1
snake1 Posts: 567
edited December 2012 in Electronics
Hey crew, I need to know where to find a trigger wire to go from my Onk to the 2250. Any suggestions or links would be great! I thought a simple stereo 3.5mm wire would do it but I'd rather get the right thing!
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • Irrenhaus
    Irrenhaus Posts: 1,105
    Try emailing Parasound they are pretty good responding back very quick. Try Richard at Parasound last time he help me out with some need it information.
    richard@parasound.com
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Irrenhaus
    snake1 wrote: »
    One more thing, I am not sure about the 809 but on my 709 the 12v trigger is only for the second zone. You may want to check that on the 809. I have been using audio sense on my 2125 and have not had any issues so far.
  • Emlyn
    Emlyn Posts: 4,888
    I think, like most Parasound amps, the 2250's input trigger jack is a 2.5 mm one. The trigger jack on almost all other gear is 3.5 mm. I'd recommend getting a 3.5 mm to 2.5 mm cable from Parasound as they are not commonly available, or you could try splicing one together or buy an adapter from PartsExpress.
  • adb3da
    adb3da Posts: 507
    I'll add that in my experience you need to make sure you use a mono cable and not stereo.
  • Syndil
    Syndil Posts: 1,582
    Yep, should be mono, and the 2250 does have a 2.5mm jack. Get one of these:
    http://www.ramelectronics.net/product.aspx?zpid=440
  • snake1
    snake1 Posts: 567
    Irrenhaus wrote: »
    Man, I think your right.... great...
    Those of you using audio sense, where do you have your knob set??
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • Irrenhaus
    snake1 wrote: »
    I have mine set a the minimum level.
  • snake1
    snake1 Posts: 567
    Very good I was kinda confused about whether it should be set on minimum or maximum. I have had it set on minimum most of the day and the music very low and it's been working very very well! Maybe this is the fix.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
