Stand for CiA6
pablo_rodz
I'm putting together my home theater, and need suggestions for a center channel stand. I've done some researching, but the stands I've seen seem small for the CiA6.
The speaker will be placed below a 100" screen.
Thanks in advance.
Thanks in advance.
HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
Living Room:
Stand just for the center or other gear as well?
Sanus has a couple center channel stands. 18" or 22" tall and you can fill the legs with shot/sand if you need to stabilize it.
http://www.sanus.com/us/en/products/speaker-foundations/sp-steel/SFC18
http://www.sanus.com/us/en/products/speaker-foundations/sp-steel/SFC22Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
I just went down to Lowe's and bought a shelve 36 x 12 and two brackets for my CsiA6
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Polkie, do you have a picture of it?
I've seen the sanus, I like the steel foundation collection, but the "shelf" piece is smaller than the speaker. I was worried of the stability and proper support.HT:
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
I would build a wood stand out of pine board. Make it the height and with you need and paint it black. Look like a side ways H with 2 offsets supports in the middle. Cheap and affective. Just my thoughts.
If your handy you could build it yourself with simple tools. Strongly suggest you get all you measurements/drawings on paper and get to cutting
Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000
