Veneer or Wood on SRS SDA's
Robert Scott
Robert Scott Posts: 29
edited November 2003 in Flea Market
I alway's here everybody saying their SRS SDA's have wood veneer.I sware mine are solid oak top, bottom,and sides.Can anybody enlighten me please
Polk:SRS-SDA's front Speakers
Rotel:RSP-985 Surround Processor
Denon:POA-2400 Amp
Post edited by Robert Scott on
  • scornful
    scornful Posts: 272
    Never owned them, but real wood is dimensionally unstable at differnet temps, humidities etc. For this reason I'd say veneer. Maybe really thick 1/4" veneer but veneer none the less.
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
    InFocus 4805 ~100" Screen
  • Strong Bad
    Strong Bad Posts: 4,278
    Solid oak on top and bottom. Atleast with my SRS 2.3's.
    John
    No excuses!
  • dorokusai
    dorokusai Posts: 25,609
    The end caps are solid wood, but the sides are a type of pressboard, very cheap.
    I remounted the side panels on my SDA's and was pretty suprised that it wasn't real wood. It feels more substantial and harder when mounted.
    F1nut Posts: 52,204
    Robert,
    The top and bottom are solid oak or walnut, the edge of the top and bottom are veneer and the side strip is solid wood. On the early models the top and bottom were glued up boards (solid wood), but on later models it's one wide solid piece of wood. The only veneer on any of them is the edge banding. Should you ever need to remove them, they are held in place by 4 bolts accessed by removing the top drivers and the bottom PR. As Doro stated, the cloth covered side panels are some kind of pressboard and can break easily if you need to remove them. No problem really as they can be replaced by the right size and thickness of MDF.
    You are now enlightened.
