Fix SRS Badge
xsmi
xsmi Posts: 1,798
edited December 2012 in Vintage Speakers
I came in today and the SDA-SRS Badge was drooping. The peg that holds it in the grill broke. The badge itself seems to be some sort of metal. What would you guys recommend to re-attach the peg to the badge? Would JB Weld work?
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
    Toolfan66 Posts: 17,333
    Yep!!
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • xsmi
    xsmi Posts: 1,798
    Thank you.
