Psw 125
David Ball
I need to remove the amplifier from my woofer. I have remove all the screws but am unable to remove it from the enclosure. What is the best way to get the amplifier out?
Should just pop out. Double check that you didn't miss a screw or 2 (I've done that). Might need to use a putty knife to get it started.
