SDA SRS 1.2 questions?
Dabutcher
Dabutcher Posts: 2,606
edited December 2012 in Vintage Speakers
I have mine torn apart . Dynamat,JB Weld,RDO 194's,Larry's Rings. I just purchased a Adcom GFA 555 to try something different w my speakers . I have not listened to this amp yet until the mods are done. If I really like the sound would it be worth the trouble and effort to get a matching GFA 555 and run the two as monos? I understand that I would have to purchase or build a dreadnought transformer to make it work? Also if the bare drivers and tweeters are stamped 1988 does that give me a good idea of year they were made? As always thanks for all the help. My ears and pocketbook thank you! Darryl
Post edited by Dabutcher on
  • soundfreak1
    soundfreak1 Posts: 3,414
    Tjat tells u when the drivers were made. However u can draw a conclusion that the speakers were made fairly soon after if the drivers are original maybe withon 6 MO. or so.dont know for sure how quickly they went thru parts in production back then?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Dabutcher wrote: »
    Two comments:
    1) I don't know anything about the GFA 555 amp, but when I went from one 2-channel amp to monoblocks, the sound of my SDA SRSs made a major improvement in performance. I'm no expert, but I think added power is good for these speakers.
    2) Build a Dreadnought whether or not you decide to buy a second GFA 555. I put a Dreadnought in my system in my exercise room with a common ground 2-channel amp and SDA 1Cs, and the improvement was dramatic. And I only had a Toroid of Maryland 600VA transformer in the Dreadnought. I am sure either of the A-L isolation transformers discussed on this Forum (800VA or 1000VA) would make an even bigger difference. I'll be posting my own experience with the difference when I get my A-L 1000VA isolation transformer installed in a second Dreadnought.
