PSW111 and/or PSW505
Ok, so here is my situation. Originally, I purchased 2 PSW505 for my surround sound setup I am working on which currently includes:
2 RTI 12s
CSI A6 Center
FXI A6 rears
My dilema is with which subwoofers to choose. I orignally purchased two PSW505s. Since then, I have received 2 PSW111s for free with the current promotions. Should I stick with the two PSW505s or replace them with the two PSW111? Or should I run one of each?
Money is not a deciding factor. I am looking for the optimum sound quality for my home theater system. Please share your advice or experience!
Post edited by ScottDAndersen on
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited December 2012
    I would expect the 505's to be better, but try'em out who really know's what will sound better in your room better than you and your own ears.
    EndersShadow Posts: 17,705
    505's will be better, not even worth testing the PSW111's out. Keep em in the factory box and sell as such.
  • rooftop59
    rooftop59 Posts: 8,121
    Agreed. Its no contest, and you will get more money if you keep the PSW111s sealed. However, if that really doesn't matter to you, then I guess why not try them.
    Welcome to CP!
    Game Room 5.1.4:
    Bedroom 2.1
    Welcome to Club Polk!
    While the 111s may be a little more musical, maybe? With two Rti-12s up front you really need the power and lower LFE range of the PSW 505s or even something "better"?
    cnh
  • chumlie
    chumlie Posts: 8,658
    +1......
  • ScottDAndersen
    ScottDAndersen Posts: 9
    thank you eveyone! Ill keep the PSW505s and sell the others.
  • slider2828
    slider2828 Posts: 118
    Definitely 505 as well.... Welcome to forum
  • oleon621
    oleon621 Posts: 178
    I currently have the psw505 and it does an ok job overall. I think it suffers in the low ranges personally. I would sell all your subwoofers and maybe get one of the DSW Pro subwoofers.
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
  • JJM56
    JJM56 Posts: 3
    I have a PSW111 Powered Subwoofer that I'm using for my Home theater system. It has worked fine for a couple of years. Just the other day a low thumping, clicking sound started. I unplugged the subwoofer from my Onkyo TXSR608 Home theater receiver and simply plugged the power cord in the socket. I continue getting the low thumping, clicking sound. Anybody have this problem, or any suggestions as to how to address this problem?
    Thanks...
