Subwoofer settings
friggy
friggy Posts: 66
I have a Jensen JS1000 sub, it's a 8" 100 watt sub.....okay when you're done laughing I have a few questions. 1st off my system consists of a Marantz 6007 receiver, Polk RTi10 towers, CSi3 center, Polk RTi6's as surrounds, and the before mentioned sub. Also I am looking at new subs now. But until I get a new sub I still need to use the 1 I have. My question is the sub has 3 adjustments on back; level, crossover, and a phase switch. The crossover and level I understand but what should the phase switch be set at and what does it do? The switch only has 2 options 0 or 180.
Thanks for any help.
Panasonic 50"
Panasonic BPD 50
Marantz 6007
B&W CM9
B&W CM2BG
CM 1's
HSU 3MK4
XPA 5
Post edited by friggy on
  • goofyGAguy
    goofyGAguy Posts: 545
    edited December 2012
    Sit in your preferred listening position. Play a CD with a steady deep bass line. Have a friend flip the phase switch back and forth. The correct position is the one that yields the most bass, simple as that. If you can't tell a difference, leave it at 0.
    My humble setup...
    ...is no more. :cry:
  • friggy
    friggy Posts: 66
    Ok thanks I'll give it a try. I tried this by myself but didn't to listen while someone operates the switch.
    Thanks Ken
    Panasonic 50"
    Panasonic BPD 50
    Marantz 6007
    B&W CM9
    B&W CM2BG
    CM 1's
    HSU 3MK4
    XPA 5
  • steveinaz
    steveinaz Posts: 19,545
    Usually if your sub is on the same "plane" as your main speakers, phase should be at 0 degrees. But GAGuy is right on varifying. Phase adjustment basically "synchronizes" the subs woofer movement with the main speakers woofer movement. Phase will sometimes have to be adjusted from 0 when your sub is shooting perpendicular into the room w/respect to your mains, OR when your sub is in the opposite (across the room) corner.
