computer question
sda2mike
i'm running windows, xp i think..computer is 1 yr old...anyway: i have an external hard drive i'd like to back up to my internal c drive...the software for the ext hd seem to favor backing up the c drive with the external drive...is there a way this computer dummy can back up my external drive?
thanks!
mike
thanks!
mike
There are a couple of ways to do it. The easiest would be to simply create a folder on your C: drive, name it such as "ext backup". Then, open windows explorer, select all the files/folders from your external drive that you wish to back up, click copy (edit>copy), then right-click on the folder you created on C: and select "paste".
Another way would be to use backup software to do it. That would be more complicated, but would allow you to compress the backed-up files so they take up less space on your c: drive.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
thanks tbone!
