soundbar 360 dvd Proprietary Wiring "HEEEEEEEEELP !!!!!!!!!!!!
wil2
I have attached a photo of a diagram showing the proprietary connector of my SurroundBar 360 DVD Theater system. The unit is dead and I plan on connecting the soundbar to an a/v receiver (creatively). I have mapped out the wires, and the colors correspond as shown in the hand drawn diagram attached. The diagram is looking at the proprietary connector cable end (females). I would like to know which set of plug-ins, as you see this diagram, are the (+) positive bank of wires and (-) negative bank. There is a "guide keyway" built into the plug at top shown in the diagram which only allows the plug to go in the unit "one way". The Positive and Negative indications on the diagram are just for my own orientation for speaker connection purposes. I need a super geek on this one. Thanks for any help !!!
Hello wil2,
Welcome to Polk's forum. I think I understand what you'd like to do, but because of the unique nature of the SurroundBar's speaker system I'm not sure connecting it to your receiver is such a good idea. I don't think the sound would be acceptable. But, any wiring information would be found at Polk's CS department, either by telephoning 1-800-377-7655 or sending them an email to: polkcs@polkaudio.com.
Regards, Ken
