wife cleaned projection
bass addict
My wife decided to clean the RPTV without thinking. She cleaned it with windex and a soft cloth. I know in the manual it states to use water or mild soap if needed. Is windex going to damage anything or should it be fine? I just need to know if I am going to have any problems.
Post edited by bass addict on
not sure about rpt's, but nh3 attacks the anti-reflected coating used on monitors and direct views.
i'd go back over the screen with cloth damened with distilled water...More later,
Tour...
Vox Copuli
i'd go back over the screen with cloth damened with distilled water...comment comment comment comment. bitchy. -
nh3 = ammonia
can you handle h2o?More later,
Tour...
Vox Copuli
Good lord......h2o is common enough, but I don't go around interpreting chemicals as their periodic values......(though I think that salt is nh22.....maybe)comment comment comment comment. bitchy.
Table salt = NaCl
aka sodium chloride
I called the tech line at Hitachi and she said it shouldn't cause any harm. It is just not recommended to do it. I guess I'll let my wife stick around. LOL
monster recalled their screen cleaner a while back because it had alcohol and was eating a few screens. oops! new, alcohol free kind is out now.
Originally posted by brettw22
nerds.......;)
We'll not see him no more
For what he thought was H20
Was H2SO4! :eek:
Rgds,
--pete -
nasty stuff indeed. makes hcl look like nothing... then again there's hf...
based on posted photos, brett should know h2o2...More later,
Tour...
Vox Copuli
I've used Windex on my Hitachi big screens many times without any damage, now if I can't just teach the dog to quit bumping them with her nose.
Regards,
PolkThug -
the wendex will soffen the scratch restance of the screen that is y you dont clean tinted windows with it.
Looking for a good cleaner, I use one called Zani Glass. its made my a company called Crestec. It has no ammonia & claims to be enviormentally safe, it is made for glass, plexiglass, metal , chrome, laminates etc. I been using this on my 100 gal plexi glass fish tanks & the smaller 55 gal glas tanks for about 9 years & it works! This is the only cleaner that Id use on my large tanks. I tried it on my Mits 55" screen & awsome job it does. I just spray a very light mist on to a soft cloth & wipe the screen till its clean & rewipe with a seccond cloth. I use this on my pws 650 & LSI speakers keeps the gloss black shiny & clean. It claims to clean the surface than put a invisable protective sheild which protects the surface & be resistant to fingerprints, dust & dirt buildup. I buy this from our local appliance parts company here. Whatever you use dont spray the cleaner directly on to what your cleaning, you dont want it to run into your equipment.
"Clear Guard" brand also works....any brand window cleaner, ammonia free, silicon based will do no harm to that material.
Eagle One, auto store brand, makes a tinted windows safe cleaner which would also do just fine.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
theres H2S if you want your teevee smelling neat too
