3.1TL Wiring Harness
Drenis
Drenis Posts: 2,871
edited January 2013 in Vintage Speakers
Fellow 3.1 owners... any of you have a picture of your harness for the mid woofers?
While I had mine apart, I found that mine were both wired strangely. I'm curious if ALL 3.1TL's were wired the same as according to the scematic, a posative lead should go to all 4 MW and a ground should go to all 4 MW... but it's not that simple. Is there supposed to be some series wiring in there?
Post edited by Drenis on
  • brgman
    brgman Posts: 2,859
    edited December 2012
    I think i have one i got from tollfan a while ago.If you don't get what you need i'll dig it out and take a pic and see if it tells you what you need
    I’M OFFENDED!!!!
  • Drenis
    Drenis Posts: 2,871
    Bump... anyone?
    brgman??
  • brgman
    brgman Posts: 2,859
    Let me find that box.Might not be til later on but i'll see if i can posta few pics of what i have.
    I’M OFFENDED!!!!
  • Drenis
    Drenis Posts: 2,871
    Alright in the mean time while brgman searches for what he's looking for, all our SRS models have 4 stereo drivers. How are the MW wired inside the 2.3 and 1.2 models?
  • PolkieMan
    PolkieMan Posts: 2,446
    http://www.vr3mods.com/LCSDAUpgrade.php
    FOR DOWNLOAD: The SDA Handbook. By Ray Smith
    Page 70 #18 Hope that helps?
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    I found a picture I took when I first got my speakers that shows what I'm trying to inquire about. Have a look at the wiring. When I hooked everything back up, black is always positive... It also is on the next driver that black branches off to.
    VR3 Posts: 28,782
    edited January 2013
    Man I am going completely off memory but I think there may be some series wiring going on in the 3.1TL. Unfortunately my photographic memory is not 100% and I did not take a picture of that test so I don't have any records...
    Maybe Mike R would be able to help as he just hooked his back up within the last month or so
  • headrott
    headrott Posts: 5,496
    edited January 2013
    I will probably be taking m ine appart in the next week or so, so I can add the plexiglass Gimpod board reinforcements to the crossovers. I can take some photos of the wiring then if you wouldlike. I have many other things I need to do along with this, so I cannot guarantee how long it will take to get it done. I hope I can help you out though.
    F1nut Posts: 50,753
    edited January 2013
    The wiring in your pic is correct. That white lead coming off the black/white should have a small piece of black tape at the other end indicating that it is positive.
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    Great guys. That's all I wanted to confirm.
