One speaker louder than other
  • Polka_sound
    edited January 2013
    Umm any tips on how to remove the drivers without damaging the baffle? Should I use a screw driver to pop the drivers out? They seemed glued to the speakers almost. Tried pulling it my fingers and nails and couldnt get it to bug. When I use a screwdriver I leave marks on the baffle around it :(
  • KellyMic
    edited January 2013
    If you aren't careful you could void your warranty. Call Polk CS before you go that route.
    Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
    Crown D-75, Crown CE1000, Crown CE2000
  • jeremymarcinko
    edited January 2013
    perhaps the malfunctioning tower is the louder one not the softer one. Im not very smart in this area but couldnt one check the crossover/drivers resistance from the terminals with a multi-meter. Thinking maybe the louder one is running under 8ohm and drawing more current.
  • HTguru1982
    edited January 2013
    Make sure all of the wiring inside the speaker is okay. I recently had a pair of speakers shipped to me and after hooking them up, I found that one of the tweeters didn't work. I removed the tweeter and one of the wires had become disconnected, presumably during shipping. It took a few seconds to fix.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • Polka_sound
    edited January 2013
    HTguru1982 wrote: »
    Thats what I want to check will this void the warranty?
  • sodablue
    edited January 2013
    If it's still under warranty it's best not to touch it. Call Polk and ask them what to do.
  • Polka_sound
    edited January 2013
    sodablue wrote: »
    Ok I will do that thanks
