Do Larry's Rings mod need to have Mortite?
Dabutcher
Dabutcher Posts: 2,606
edited December 2012 in Vintage Speakers
I am ready to install my Larry's rings and I bought some Mortite putty and was wondering what everyone does? Add the Mortite or leave it alone? As always ,thank you for all the help. Darryl
Post edited by Dabutcher on
    F1nut Posts: 51,997
    Stock gaskets in good condition? If so, you don't need to do anything. If not, use Armacell, do NOT use Mortite.
  • Dawgfish
    Dawgfish Posts: 2,554
  • nspindel
    nspindel Posts: 5,343
    ^^+2^^ Stay far away from Moretite. Armacell is great stuff.
  • Jimbo18
    Jimbo18 Posts: 2,351
    Has anyone tried silicone caulk instead of Mortite or Armacell? Seems like it would seal well and be easy to apply.
    F1nut Posts: 51,997
    You mean like bathroom silicone caulk? Not a good idea for many reasons including you don't want silicone anywhere near your speakers.
  • dscheer
    dscheer Posts: 47
    The problem with silicone caulk Jim, is that when/if you need to remove the driver the caulk sticks both to the Cabinet and the driver flange. If you ever remove the driver again, this usually results in the caulk tearing off some of the MDF cabinet material and also can tweek the driver basket (Distort the Flange). The caulk does make a good air seal, However; as F1nut shared, stock polk gaskets (in good condition) or armacell work great. Something to consider about driver mounting: You are not only trying to get a good air seal, you are also trying to have the driver coupled to the cabinet, Some sealing materials create a cushion that allows the driver to move in/out, thus losing the dynamic impact the driver may be able to produce. and lastly, you want to be able to remove the driver without damaging the driver flange or the cabinet.
    Regards: Don Scheer.
    Donto's System:
    Parasound HCA3500
    Parasound HCA 1500a (4 each)
    DIY Set Tube Amps (4 each)
    Parasound 850 Pre-Amp
    Onkyo CD Player
    Teac Tape Play/Recorder
    Samsung 50" TV
    Toshiba HD DVD Play/Recorder
    Polk RTA12C Speakers
    DIY 15" Side-Firing Subwoofers (2 ea)
    DIY 15" Down-Firing Subwoofer
    Adcom Power Conditioner
    DIY Isolation Transformers/Power Conditioner
    4 ea 20 Amp Power Circuits
  • Jimbo18
    dscheer wrote: »
    Thanks F1 and dscheer. I was sure it was a bad idea, because I haven't seen it mentioned here anywhere and it would be easy to apply.
    I googled Armacell and there are a lot of different products but I couldn't tell what "model" exactly would be appropriate. Is it similar in application to Mortite, which I have used in the past?
  • Dawgfish
    Armacell can be readily found at Home Depot or Lowes. The one I use is designed for windows and doors. It's very easy to work with and works great. I don't see any reason to use anything else (excluding Brgman's gaskets of course) if you need some sort of gasket/sealer for your drivers.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Dabutcher wrote: »
    I found that Armacell tape was a better seal than Mortite with Larry's rings. My comparison notes are here: SDA-Driver-Seals-Original-Foam-vs.-Mortite-vs.-Armaflex-Foam.
  • Jimbo18
    Thanks for the link, DK. Impressive review as always. I think my 7's will thank you for this.
