Roof leaking fix idea
BlueFox
BlueFox Posts: 15,251
edited December 2012 in The Clubhouse
About 10 years or so ago I had my roof replaced, and so far it has held up quite well, except for one area. The last couple of years when it rains really hard for an extended time, there are drops coming in on the left side of the fireplace chimney. I have tried finding an opening, and spreading the black roof patching tar around it, but water still makes it in.
Anyway, I bought a heat gun and I am going to try melting the tar around the chimney with the hope it will ooze into any cracks and stop the leak. However, before I try this I thought I would ask if this is a reasonable idea, or will the tar go up in flames and I burn down my house.
Post edited by BlueFox on
  • soundfreak1
    soundfreak1 Posts: 3,414
    Use the "right tool for the right job"
    Call a roofer!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • BlueFox
    That is an option, and probably less expensive than replacing a burnt down house. Of course, they will probably just use a heat gun to melt and reseal the tar. :smile:
  • goofyGAguy
    goofyGAguy Posts: 545
    Yes, in this case a credit card.
    My humble setup...
    ...is no more. :cry:
  • Polkersince85
    Polkersince85 Posts: 2,883
    Set the attic on fire and then go on the roof to see where the smoke is coming from. Look for cracks in the brick and around the liner too. Water may be backing up and over the seals so just re-melting may not do it.
  • chumlie
    chumlie Posts: 8,658
    Sounds like your flashing is the problem. Try FlashSeal. Make sure you get the reinforcement fabric to go with it. Great product. I've used it with great results, as in no more leaking. It will last a couple of years. If you plan on staying i would get a roofer to redo the flashing. No telling the damage its already caused that you can't see.
  • WilliamM2
    WilliamM2 Posts: 4,782
    Yep, sounds like you need new flashing. If it started leaking after only 8 years, I'd hardly call that hloding up well. It should be replaced everytime the roofing is, but many roofers will cut corners and skip things like that to make more money, or get the lowest bid.
    I'd call a roofer, who knows what else isn't right.
  • Devlon
    Devlon Posts: 355
    I had a friend who used Flex Seal (Similar to Flash Seal) with good results. I understand Home Depot carries their own brand of it.
    Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
    2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
    Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
    1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
  • jbooker82
    jbooker82 Posts: 1,627
    Devlon wrote: »
    Its like a Handy Man in a Can.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • oldmodman
    oldmodman Posts: 740
    When I had my entire roof replace eight years ago the roofer paid special attention to the area around my chimney. It was the only area that I had repeated leak problems with.
    The roofer used a special saw to cut an angled slot all the way around the chimney. The flashing went into the slot and was glued in place. Then it went down onto the roof and was covered in roofing "shingles"
    Never leaked since and it survived one decent earthquake that was strong enough to shake loose a cap brick.
    Good flashing solved all my leak problems. Not that it ever rains in Los Angeles.
  • decal
    decal Posts: 3,205
    Get it fixed right, don't half-**** it with tar or other sealants.
  • 11tsteve
    11tsteve Posts: 1,166
    oldmodman wrote: »
    this.
    when we apply a steel roof, this has been our procedure and it works quite well. we use an angle grinder with a thin masonry wheel, and usually NP-1 caulk for the groove. if necessary, small Tapcons can be also used to keep the flashing in place.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
