I have the speakers but need Links for possible receivers You suggest Thanks.
dizzyrapper18
dizzyrapper18 Posts: 15
edited November 2012 in Electronics
So I bought these speakers for my first step in my first home theater system. Not sure of room size yet as I'm going to be moving within a month or 2. I know a little bit on what to look for in an AVR but still not comfortable yet. What are some Major must haves in AVRs to be great.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290210
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290200
Heres the receivers on newegg and when I search I look at the most reviews and top rated. I also was thinking on saying screw it and look for a 7.1-7.2 AVR. which is better? Can I get some options from You about what You think would be a good fit for the speakers I recently bought?? Doesn't have to be with newegg but I've bought everything else from there. I would be greatly appreciated with what you guys suggest.
http://www.newegg.com/Receivers/SubCategory/ID-488?Order=REVIEWS
i was also looking at the anventage series by Yamaha which looks decent but expensive so i was thinking of the RX-A720. i know its the lower version (should i say screw it and maybe go next step up?) but should it do the trick or should i look at something else? I'm looking for opinions on what you think would be nice so links would be greatly appreciated. Thank you for the help.
Post edited by dizzyrapper18 on
  • BigDaveyL
    BigDaveyL Posts: 36
    I am driving almost the exact same set up (just a different Polk Sub - PSW110) with a Pioneer VSX-1021-K. Looks like those are heavily discounted by NewEgg from time to time.
  • sandworms
    sandworms Posts: 1,043
    Welcome to the club, get your shop on here http://www.ebay.com/itm/PAIR-Monitor-60-CHERRY-Towers-Polk-Audio-/390309003878?pt=Speakers_Subwoofers&hash=item5ae03ac266
    Always great deals on near new speaks, and as far as an AVR, give us a budget. There are to many to suggest w/o knowing your $ limit
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • dizzyrapper18
    I was wanting a 7.1(2) AVR maybe I can do this instead of upgrading later ifIi want to get more speakers, not sure though so I've decidedIi would just go with a 5.1 AVR but spend around 550$ max maybe 450$-550$. Being I haven't found a new house yet, not sure how big the room is and I only have 5 speakers and probably not getting anymore anytime soon. I would love some links on suggestions that people have that would benefit me greatly. Thank you.
  • rpf65
    rpf65 Posts: 2,127
    Just because you buy a 7.1/2 or 9.2 doesn't mean you have to fill all speaker channels. No problem at all to run 5.1 off a 9.2 AVR. The problem would be wanting to run a 9.2 set upoff a 5.1 AVR.
    Gett all the bells a whistles you think you want, and pre outs, if in your budget.
    If you don't want to buy new, check Crutchfield outlet, Best Buy open box, or any other reputable internet retailer. You can find a lot of good buys.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Pre amps outs is great upgrade later and will save you some cash later.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
