Anyone using X10 here?
disneyjoe7
disneyjoe7 Posts: 11,435
edited November 2012 in The Clubhouse
Trouble with sending signals around house, and use a X10 repeater / coupler which helps but still have issues. Can I use 2 repeaters? I believe my issues are due the having 3 electrical / CB panels in my house.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • maximillian
    maximillian Posts: 2,144
    They have X10 signal diagnostic tools which can help you troubleshoot where the signal is getting lost, or interfered with. Repeater / couplers aren't going to solve your problems if you have a lot of noise on your lines. The best advice is to dump X10 and move to either Insteon and Z-wave. More expensive but they have a better future IMO.
  • WilliamM2
    WilliamM2 Posts: 4,782
    2 repeaters may cause more issues, and probably won't fix the problem. Usually issues are caused by having items on different phases, more panels shouldn't be an issue, other than distance. This guy makes custom coupler/repeaters that are far beter that X-10's:
    http://jvde.us/xtb/XTB-IIR_description.htm
  • disneyjoe7
    WilliamM2 wrote: »
    Background.
    I have a repeater off one of my sub panel, and for most times it works fine controlling my house outside lights controlled by my pool Intellitouch system.
    Would a .1uf 600v cap work on the main electric panel if I need a signal back on the other sub panel vs another repeater?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
