two receivers
seabeerob213
seabeerob213 Posts: 1,843
edited November 2012 in Electronics
is it possible to run my hdmi out from one receiver to the hdmi in on a second, just to use the first as an hdmi hub, will have all speakers connected to the second, or can i put the first to the rear of the room to handle my surrounds, but run still have them connected
Post edited by seabeerob213 on
  • halo71
    halo71 Posts: 4,640
    Why or what made you think that you should or could or need to do this? What are you trying or wanting or hoping to gain from doing this?
    --Gary--
  • seabeerob213
    the receiver i want to use doesnt have enough hdmi ports, so i figured i'd ask, im new, and fairly curious and wanting to learn
  • Irrenhaus
    Irrenhaus Posts: 1,105
    Why not an HDMI Switch.
    http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=6259&seq=1&format=1#largeimage
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • seabeerob213
    i forgot those existed honestly, im still curious as to whether or not the two receiver idea will work though
    txcoastal1 Posts: 13,519
    theoretically it would work, all the audio would have to be on the same unit because of the surround processing
  • seabeerob213
    ok, i think i'll go with a switch though
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    You could try that idea, but I'm not sure if that would work. My thinking is the first receiver would strip the audio off the hdmi signal being passed to the other receiver.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
